Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Bad slides?
  1. #11
    Join Date
    Oct 2001
    Surrey & boat in Dorset. Both have pubs
    Posts
    3,598
    Default Re: Bad slides?
    Quote Originally Posted by savageseadog View Post
    There's lots of models and sizes, the wrong ones will jam.
    Agree. It sounds like the shoulder of the slides is getting stuck in the slot.
  2. #12
    Join Date
    Jan 2010
    Kent
    Posts
    702
    The sail isn’t full battened is it ? You wou need a pressure slide with rollers fitted at each batten end .
    One other thought ,how were the slides attached on the old sail .? webbed on or shackled.
    If shackled on now ,they may be too loose and get dragged up to tip .
    If webbed on that’s a more rigid mount,often slides easier.
    There are many slides now that are designed to stop the angle change ,they have a rockered back face.
    Do you know your mast manufacturer?
  3. #13
    Join Date
    Nov 2011
    Nelson New Zealand
    Posts
    561
    I bought a new fully battened main to replace the old baggy thing.
    At first i though that either I or the sailmakre had made a mistake, cos it was a bit ch to raise and lower.
    One can of silicone spray later, it was a completely different story.
    I use the silicone spary into the track as far as i can reach and onto the slides when the sail is down, but only once or twice a season.
    I can now hosit the main by hand, only needing the winch to apply final luff tension.
    Aiming to live forever or die in the attempt!
  4. #14
    Join Date
    Aug 2001
    Lancashire
    Posts
    1,375
    Quote Originally Posted by Cardinal View Post
    I would recommend Tidesmarineís sailtrack system. I think you would find the difference remarkable.
    No connection- I have it as recommended by my sailmaker and find it takes a lot of effort out of sail hoisting and lowering and certainly you would not need a hand at the botto: of the track as the slides are contained.
    I second that. I fitted a Tides Marine track system last year. Not cheap but well worth it for me as I have a poor sense of balance and didn't like having to balance on the coach roof in choppy conditions to pull the last few metres of sail down. With the Tides track it comes down like a runaway train.
    https://www.youtube.com/watch?v=fVEX4DCfCYE
  5. #15
    Join Date
    Dec 2008
    tayvallich
    Posts
    2,877
    Quote Originally Posted by JimC View Post
    Thanks for that. I think i am heading that way too - old circular section mast track for a luff rope main, cars jam unless heading straight upwind etc. Cheers for vid.
  6. #16
    Join Date
    Oct 2001
    Posts
    3,598
    Quote Originally Posted by pompeydave View Post
    The slides jam even when just testing the sail on the berth in zero wind. Starting to think it’s a lubrication issue.
    Incorrect slides if jamming like that. My main was getting difficult to raise and lower and I found that the masthead shaves had corroded after 40 years. Cleaned them all up during a re-rig so hopefully back to undoing haliard and main drops down .....
  7. #17
    Join Date
    Jul 2004
    Portsmouth
    Posts
    65
    Hi all, lubrication was the issue- added McLube up and down the slot and on the slides and its smooth as silk now! Thanks for the advice.
  8. #18
    Join Date
    Dec 2008
    tayvallich
    Posts
    2,877
    Great - and thanks for letting us know ☺
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
