Page 4 of 17 FirstFirst 12345678914 ... LastLast
Results 31 to 40 of 166
  1. #31
    Join Date
    Sep 2016
    SoF
    Posts
    9,122
    Default Re: Torqeedo Outboards?
    Quote Originally Posted by RupertW View Post
    If cost is even in your calculations then I would forget about Torqueedo for another few years. For us it was a complete indulgence and delivered all the advantages we hoped for and a couple more.
    I agree with Rupert. You cannot make a direct comparison, you have to not want a petrol outboard. Either because its too heavy, too noisy, smelly, you dont want petrol onboard, too difficult to start etc. But if you want cheap to buy, more power, more speed unlimited range then petrol is still the way to go. In my case it was to get petrol off my boat.
    Neither a Leaver or Remainer be
  2. #32
    Join Date
    Sep 2016
    SoF
    Posts
    9,122
    Quote Originally Posted by nestawayboats View Post
    Regards locking either Torqeedo or Epropulsion motors, yes a padlock through the handles or - better, as the handles are only plastic - an "outboard tube lock" (various suppliers) that slides over the handles to stop them being undone or snapped off. Then a bike cable through the battery and if you're feeling paranoid (in the case of the Torqeedo) take the tiller (which is removable on the Torqeedo, foldable on the Epropulsion) with you. If you take those precautions, harsh as it may sound you've made it easier - for the potential thief - to nick somebody else's motor.
    Some customers do take their batteries ashore, but this is usually more about grabbing the opportunity to "refuel" (their battery as well as themselves!) in the pub, than security. Torqeedo mains charger is 90W (so you get about 10% charge of the 916Wh battery per hour on the mains); Epropulsion standard mains charger is 175W (about 17% per hour of their 1018Wh battery); and with the Epropulsion there is a 400W fast charger option (2.5hrs to full charge from flat). Both manufacturers offer battery bags as options, with rucksack-style straps in the case of the Eprop.
    Lastly I'd point that certainly when I was last living in the Caribbean - nearly 20 years ago, unfortunately - there was a disincentive to making the outboard too difficult to steal, because "they" did usually only want the outboard. (Outboard motors being relatively portable and valuable per kilo, with a ready market, compared to boats.) We heard of a few dinghies where the outboard was too secure so the thieves had either hacked the transom out of the boat altogether (in the case of inflatable floor boats), or sawn out the relevant bit of the transom on RIBs.
    Ian, Nestaway Boats
    Thanks Ian. Yes, a lock is to keep an honest man honest not keep a thief out. Ive had a 150 hp outboard stolen so even weight is not an issue to a determined thief. And Ive had two and half thousand worth of damage to my sliding glass door so someone could steal a bottle of water from my boat. I guess I was hoping there was a high tech Torqeedo solution to the problem
  3. #33
    Join Date
    Apr 2010
    Christchurch, Dorset
    Posts
    53
    Quote Originally Posted by pcatterall View Post
    Our Seagull might be getting a little long in the tooth and we often discuss what we would replace it with!
    Our Avon Redstart is an exact fit in its ideal storage location so we want to keep that.
    We don't expect to be planning!
    I hear that Torqueedos' are very expensive but some new outboards also seem pricey.
    I guess that the max size we would want would be 2.5hp so can anyone offer an aprox cost comparison new outboard against new Torqueedo and the relative life expectations?
    If you shop around you can pick up a Suzuki 2.5hp outboard new for about 525, or a Torqeedo 503 (sold as "1.5hp equivalent") for around 1125 - including from us should you wish (we sell the Suzukis too!). So if you want an electric outboard with an integrated lithium battery (ie the type discussed here), it's going to be double the money, or triple the money if you want more power and/or larger battery. In terms of speed and shoving power a 503 will do pretty much everything that a 2.5hp petrol will on an Avon Redstart, because as you say there is no chance of it planing. There are many variables but my reasonably informed guesstimate is that you'd get about 4 knots flat out and 3 knots at half power, using a 503 on a Redstart.
    You could go electric for much less than that if you bought a 12V trolling motor and don't mind having a car battery in your dinghy, but that's a lot slower and less convenient. With apologies to whoever I'm paraphrasing, trolling motors are basically designed so that you can push your fishing boat along slightly slower than a lazy fish, rather than for propulsion. (The Torqeedo and Epropulsion motors were designed mainly for propulsion, but if you want to go slowly to catch fish they can do that too.)
    As one of the other posts here states, if upfront cost is a major consideration then this type of electric motor cannot compete. But if you're going to pay an authorised dealer to service your petrol outboard - which is usually a term of the warranty - then over 5-6 years the lifetime cost starts to even out. (Based on it costing you 100 a year to have a small petrol motor serviced and getting it to/from the dealer.) That's before any additional maintenance costs such as cleaning out the carburettor because the fuel's evaporated out and left what looks like varnish behind (a very common problem, and not covered by warranty), if you don't do that yourself. The two brands of electric outboard we're discussing here don't require any servicing (other than DIY jobs like greasing the clamp screws) for the first 8 years. And in our experience very rarely (far less frequently than petrol outboards) go wrong.
    Whether it's worth the extra upfront cost depends on what value you attribute to the many positives for electric, as listed by us and others in this thread.
    Ian Thomson
    Nestaway Boats
  4. #34
    Join Date
    Jul 2003
    River Itchen, Southampton
    Posts
    6,960
    What a great thread with balanced, informative, non evangelistic opinions based on real experience and knowledge.
    So different from the I bought and X and you must be an idiot if you dont or worse my mate bought an X and..... type thread that appears too often.
    Sorry Ive nothing at all to contribute just wanted to say I enjoyed reading it and learned something!
  5. #35
    Join Date
    Oct 2001
    Surrey & boat in Dorset. Both have pubs
    Posts
    3,722
    Quote Originally Posted by Elessar View Post
    So different from the “I bought and X and you must be an idiot if you don’t” or worse “my mate bought an X and.....” type thread that appears too often.
    Sorry I’ve nothing at all to contribute just wanted to say I enjoyed reading it and learned something!
    Not the only one.
    I'm getting tempted towards these but it is the range and charging that worries me.
  6. #36
    Join Date
    Sep 2016
    SoF
    Posts
    9,122
    Quote Originally Posted by Boathook View Post
    Not the only one.
    It’s important to have a charging system in place otherwise you get range anxiety and go everywhere at slowest possible speed always watching your battery life (range anxiety is also common with electric cars). But once you know you can always recharge then life becomes easier and you can have fun with it
  7. #37
    Join Date
    Apr 2010
    Posts
    53
    Not the only one.
    RANGE. With the Torqeedo 916Wh battery (largest one they do), of course it depends on the dinghy, load, conditions etc, but as a rough guide you should get 1hr at about 5.5 knots (flat out), 2hrs at 4.5 knots, 4hrs at 3 knots. And so on - range/run time increasing with decrease in speed - but we've never been patient enough to exhaust a battery at lower speeds! Most yacht-tender-type customers seem to buy them reasonably convinced they'll get a day's normal use out of the battery, and then find they get a weekend or more in reality. We have several customers using them on much larger and heavier dayboats (Drascombe etc) and they don't actually get much less range (heavier, but easily-driven displacement hulls). The Epropulsion battery has about 10% more capacity than the largest Torqeedo option.
    CHARGING. Assuming your usage means you do actually get 2 to 3 days out of one full charge, charging may be less of an issue than it first seems. Both makes of battery can be charged from mains (chargers supplied) or 12V DC on board (optional chargers). But your yacht might not have a large battery bank, so then you'll probably only want to charge the outboard battery when you're running the yacht's engine. Maybe attached to a circuit with a voltage-sensing relay (not standard but we know a man who has done it) so it can only charge when the yacht engine is running. The numbers still look OK for a lot of users. Take as an example the Epropulsion 1018Wh battery and its 12V 120W charger, assume an average use of 400Wh per day on the outboard, and 2hrs charging from the yacht engine (in/outof harbour etc). 2hrs at 120W should be 240W but as I want to make the maths easy let's be pessimistic and say 200Wh charge input per day. Then we get:
    - Day 1 1000Wh (fully charged) - 400Wh usage, +200Wh input, end of day you still have 80% or 800Wh;
    - Day 2 800-400, +200, end of day 600Wh;
    - Day 3 600-400, +200, end of day 400Wh;
    - Day 4 400-400, +200, end of day 200Wh.
    Under these conditions it's not until Day 5 you have to worry about your outboard's battery charge. Possibly one day in five you may visit a marina or pub, where you can plug into the mains. But yes if you spend more than a couple of days at anchor using the outboard and not visiting the pub, now you're going to have to find another way to charge your outboard battery. On my yacht we probably couldn't live more than two days at anchor without running the main engine anyway, but I know some can.
    There are other options like solar panels and if you go for a standalone setup (a panel just for the outboard battery) we find (in the UK) realistically a 100W panel will put about 400 to 500Wh back into a battery per day, if the weather is reasonable. However if you have solar panels on the yacht already it may be better to just charge the outboard battery from the yacht's 12V system, and/or add one more panel to the yacht's system.
    It requires different thinking to the admittedly-very-easy 5 litre jerry can of petrol, but most customers find their range (and charging) anxiety is unfounded. You could also double all those range/run time/independence from mains numbers by taking a second battery, but that of course is not a cheap option...
    Ian Thomson
    Nestaway Boats
  8. #38
    Join Date
    Sep 2016
    SoF
    Posts
    9,122
    Ian Thomson
    Nestaway Boats
    Ian, is it ok to partially charge a Torqeedo battery on a regular basis?
  9. #39
    Join Date
    Jun 2009
    Posts
    12,399
    I like the idea of the Torqueedo, but it would have to change significantly before I would consider one. I'm not particularly interested in speed, but I would need a moderate increase in range, a significant reduction in price and a significant reduction in charging time. If it could give me close to 20 miles range with recharge in a couple of hours and all at a price premium of no more than 50% over a 2.5hp outboard from a decent manufacturer, then it would be a definite option, but without those improvements, it is just impossible to justify.
  10. #40
    Join Date
    Feb 2004
    Boat (now back in) the Clyde
    Posts
    5,421
    Ian, brilliant posts, some of the most informative seen on here. Big credit to nestawayboats.
    PS Hadnt been aware of ePropulsion before, but now definitely on my watch radar - though unless existing 2 stroke dies for some reason, likely to wait for price point complete below 1,000
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
