Results 1 to 10 of 10
  1. #1
    Join Date
    Mar 2019
    Posts
    4
    Unhappy Bowman OM636 Heat Exchanger
    Hi,
    My Heat exchanger has developed a corrosive hole which I doubt can be repaired.
    Seeking replacement.
    Bowman Heat exchanger for Mercedes OM636
  2. #2
    Join Date
    Jun 2001
    uk
    Posts
    2,277
    Default Re: Bowman OM636 Heat Exchanger
    Depending where the hole is , the standard way to repair is to solder close one of the tubes, both ends.
    Serck
    https://serckheatexchange.co.uk/
    might be able to help.
    David
  3. #3
    Join Date
    Mar 2019
    Posts
    4
    Quote Originally Posted by david_bagshaw View Post
    Serck
    Thanks for your interest. I did not explain correctly, the hole is inside the water jacket of the Exchanger (Die cast Aluminum) not in the tube.
    Regards
    John G
  4. #4
    Join Date
    Jun 2005
    Mid Devon
    Posts
    6,327
    If you can't get one. You can use a umiversal heat exchanger mounted on the bulkhead and connect to the engine with hoses. Works just the same as the engine mounted version.
    Brexit: Taking back our freedom as a sovereign nation.
  5. #5
    Join Date
    Mar 2019
    Posts
    4
    Quote Originally Posted by PCUK View Post
  6. #6
    Join Date
    Jun 2005
    Mid Devon
    Posts
    6,327
    Yup, that's what I said!
  7. #7
    Join Date
    Jun 2001
    uk
    Posts
    2,277
    drill hole larger and use epoxy putty? or get it welded?
    David
  8. #8
    Join Date
    Mar 2019
    Posts
    4
    Thanks for advice.
    The hole is to the inner tube and really cannot be reached. There is also a fair bit of visible corrosion elsewhere.
    The universal heat exchanger is interesting but would not get any cooling on the exhaust manifold which would create a lot of heat. Apparently a new casing is available on order, so I am going to have to go there.
    Thanks again.
    jg
  9. #9
    Join Date
    Jun 2005
    Mid Devon
    Posts
    6,327
    Ah, you didn't mention it was a combined unit!
  10. #10
    Join Date
    Dec 2008
    Posts
    127
    How much is the new replacement ?.There should be plenty of scrap engines about if you could locate them.Some years ago went to Sunbury on Thames with a friend to look at an open launch with that engine & the seller had two complete units under a sheet in the garden.
    Jim
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
