Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Join Date
    Mar 2019
    Posts
    123
    Default Do these anodes need replaced?
    Hi all
    Can someone tell me if I should replace these anodes? I'm not sure if they are considered done or not. Prop one I think yes but the hull one I have no idea
  2. #2
    Join Date
    Sep 2014
    Posts
    258
    Default Re: Do these anodes need replaced?
    The hull anode looks alright to me assuming it is an aluminium. Just needs a clean up. I would check the through hull bolts though as the fastening looks a little dated. Agree, the prop anode needs definitely doing.
  3. #3
    Join Date
    Mar 2019
    Posts
    123
    Do you also know how I go about ordering the correct replacement? Is it a case of measuring prop shaft diameter and just ordering one or is it a bit more complicated? Thanks
  4. #4
    Join Date
    Jan 2004
    Bricks & mortar: Italy. Boat: Aegean
    Posts
    10,431
    From the look of the heavy deposits on it, that hull anode shouldn't need replacing -- because it's barely working. Is it zinc and the boat usually kept in brackish water? At the very least it needs a good clean. (STOL71 is presumably basing his supposition about aluminium on your username: ally should be used in brackish water, whilst also working perfectly well in seawater.)
    Shaft anode should be ordered on basis of shaft diameter, but they also vary in length: within reason, fit the largest you can whilst still maintaining sufficient clearance for the shaft to move back and forth.
    All epigrams are false
  5. #5
    Join Date
    Sep 2017
    Posts
    769
    shaft yes
    Pear no
  6. #6
    Join Date
    Mar 2019
    Posts
    123
    Hi mac I don't know if it's zinc to be honest
    The boat was kept in granton on the east coast for the last 12 years but is now at Crinan on the west. Thanks
  7. #7
    Join Date
    Apr 2009
    Posts
    5,468
    You can buy a new prop shaft one quite easily once you know the shaft diameter. Check careefully whether it is metric or imperial.
    As regards the other one, get a multimeter and check connectivity to what the anode is protecting. Anodes last quite a long time if they aren't bonded properly.
  8. #8
    Join Date
    Mar 2019
    Posts
    123
    Mac when you say the hull anode isn't working is that a problem or just the way it is designed? Find the whole anode subject very confusing I must admit.
  9. #9
    Join Date
    Sep 2017
    Posts
    769
    Is The Crinan fresh water or salt
  10. #10
    Join Date
    Mar 2019
    Posts
    123
    Hi Harry it's salt
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
