Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Jun 2014
    Posts
    74
    Default window seal`s perpex
    looking for some channel rubber seal`s to reseal my windows instead of a lot of siicone
    they are aluminum frames with 6mm perspex in a 10mm x 12mm channel
    any idea`s as all ive seen are not right and not cheap either so im on help in locating or suggestion`s if rubber is not the best and alternative is better they are small and big
    thank`s ncik
  2. #2
    Join Date
    Feb 2010
    Posts
    1,493
    Default Re: window seal`s perpex
    I used butyl tape. Comes on a roll for sealing Windows. Cheap, and effective
  3. #3
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    43,071
    Quote Originally Posted by thegasmannick View Post
    thank`s ncik
    Dont use silicone. Sikaflex 295UV is the stuff to use for acrylic glazing if you are going to use a "mastic". It wont affect the glazing and it is UV resistant
    For rubber channels see Seals+Direct https://www.sealsdirect.co.uk/index.asp
    and/or HadlowMarine http://hadlowmarine.com/Pages/Seals%20indiarubber.html
  4. #4
    Join Date
    Sep 2001
    Home - Sothampton, Boat - Gosport
    Posts
    9,696
    After many attempts to get waterproof windows, I finally cut the channel off the frame, turning the h shape into an l, and fitted oversized panes on butyl tape, using the frame purely as a trim. Result - a dry boat for the first time in years
    Steve
    Never believe anything until it has been officially denied.
  5. #5
    Join Date
    Feb 2019
    The Known Universe
    Posts
    611
    Could not get any seals for my Windows 1977 boat(tried all suppliers) and used the 3M MARINE Product , sealed in front Perspex windows and looks great, but it
    is a sticky nightmare so be careful
    Have also used Sikaflex as above and very good to
    Flying birds have no master
  6. #6
    Join Date
    Feb 2010
    Posts
    1,493
    Quote Originally Posted by Stemar View Post
    +1 butyl tape
  7. #7
    Join Date
    Feb 2010
    Posts
    1,493
    Butyl tape is great for sealing all deck gear too. It remains flexible, and can be reused if needs be.
  8. #8
    Join Date
    Jun 2014
    Posts
    74
    all good info i am going to get butyl tape and then seal with sikoflex or along those lines
    thanks to all
    much appreciated
    nick
  9. #9
    Join Date
    Jan 2004
    Bricks & mortar: Italy. Boat: Aegean
    Posts
    10,419
    Butyl seals very well: that's what it's for. Hard to imagine the need for Sikaflex as well, or even how it might be employed.
    All epigrams are false
  10. #10
    Join Date
    Jun 2014
    Posts
    74
    butyl seals for frames and sealnt for perspex in frames as its 6mm with 10mm channel
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
