Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
  1. #1
    Join Date
    Dec 2002
    Gloucestershire
    Posts
    5,198
    Default Need more volts!
    My engine has a standard automotive "Lucas" alternator.
    It pushed out the amps but the battery volts never rise above 12.
    The regulator is internal with nothing to twiddle.
    Ideas anyone please?
    I'd rather be naked
    www.mastaclimba.com
  2. #2
    Join Date
    Jun 2013
    Posts
    3,176
    Default Re: Need more volts!
    If the voltage is definitely no higher than 12V, the alternator is kaput. Can probably be overhauled rather than replaced.
    If found in the Brexit forum, please return to the real world.
  3. #3
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    43,177
    Quote Originally Posted by Graham_Wright View Post
    First reaction is that the alternator regulator is defective but there may be other reasons,
    If you are sure that the battery is good a sensible way forward would be to get the alternator tested by an auto-electrician who can then overhaul it , replacing any defective parts.
    Lat time I had a Lucas alternator at different times I replaced the brushes, the rectifier, the regulator and the slip rings. That one, an 18ACR, was easy to work on DIY and I was able to get the parts easily. Not all are so easy DIY.
  4. #4
    Join Date
    Dec 2002
    Gloucestershire
    Posts
    5,198
    Quote Originally Posted by CLB View Post
    It is brand new (but still could be kaput I suppose).
    I have a spare.
    I'd rather be naked
    www.mastaclimba.com
  5. #5
    Join Date
    Jun 2013
    Posts
    3,176
    Has it been run at any point when not connected to a battery? That can kill the reg I understand.
  6. #6
    Join Date
    Jul 2002
    Posts
    43,177
    I have a spare.
    You say it is "pushing out the amps" Where is it pushing them ? If into the battery then either the battery is in a very discharged state, is knackered or your voltage reading is incorrect!
  7. #7
    Join Date
    Dec 2002
    Gloucestershire
    Posts
    5,198
    Quote Originally Posted by VicS View Post
    I need, and you deserve, more info!
    The batteries are fine and, once the engine is running, the alternator delivers around 20 amps.
    There is a possibility I am losing something "down, the line" but the cabling is adequate. I did put a fuse in - your suggestion Vic? That should have near zero resistance.
    I'll take some more measurements.
    I have tapped onto the raw ac for a rev counter but I can't see that would hurt.
    I'd rather be naked
    www.mastaclimba.com
  8. #8
    Join Date
    Jun 2013
    Posts
    3,176
    Where, and with what, are you taking the volt reading?
  9. #9
    Join Date
    Jul 2002
    Posts
    43,177
    Something does "not add" up right If the alternator output is only 12 volts it wont be pushing 20 amps into a decent battery. A charged battery is going to be 12.6 or higher and you wont be able to push the amps "uphill"
    Check the volts with a known good voltmeter/ multimeter at the battery terminals and at the alternator output terminals
  10. #10
    Join Date
    Apr 2018
    Mooring, Faro
    Posts
    1,335
    If the batteries are fine, as stated above, they are presumable resting at around 12.8v so surely can't be taking 20 amps at only 12v. Looks like the voltmeter is suspect. If digital, has the battery been changed?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
