Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Mar 2004
    Posts
    5,965
    Default trailer bearings popping out of the hubs
    i have a yard trailer, twin wheels either side. goes all of 200 meters from hard to parking.
    two fairly sharp turns during each run, i left the tires quite deflated, brain not engaged and one of the wheels popped off.
    there is a chunky circlip at one end of the bearing and obviously a big nut at the other end.
    the yard mechanics have had a look and fixed the bearing in place with loctite, see below, which seem to make sense to my non engineering brain.
    this is the gist of their comments:
    'The hubs have over time become oversize for the bearing due to the excessive forces on them during cornering (due to the overloading of the trailer) and due to the fact the bearings have been removed and fitted multiple times. These should be an interference fit requiring hub to be heated and then having the bearing pressed in. Today the interference fit is not sufficient to guarantee that there will not be a recurrent fault. To help overcome this, we have used a Loctite 648 retaining compound on the bearings in an attempt to retain them in the hub such that they do not force the circlip out.'
    so, i could just see how it goes, (this is the first time this has happened with a poorly inflated wheel)
    or get new hubs ?
    the trailer is never going to be used on the road, so no high speeds, 'just' cornering ...
    i dont quite understand how the wheel can pop off if the castellated nut is still fixed on ?
    what do you guys recon ?
  2. #2
    Join Date
    Feb 2015
    Conwy
    Posts
    3,893
    Default Re: trailer bearings popping out of the hubs
    Nor I. Something is lost in the telling. However thats completely irrelevant. What is, is the potential for you to do serious damage to your boat. As for Locktite, its good, but no way in hell that good. Ask them to stick a plaster on too. Belt and braces. Me, Id replace the hubs
  3. #3
    Join Date
    Mar 2016
    Posts
    947
    Utter nonesense advice from the guys telling you that.
    Iíve yet to meet anyone who has ever felt the notion to remove a bearing and then put it back on. Usually if a bearing isnít jiggered before they are removed...it most likely will be after it. Youíd never re use a bearing of that type.
    Itís likely the bearing races have disintegrated and itís gotten that bad there is little of anything left to retain it on the hub. Likely only the inner race outer shell left on the tapered hub.
    Iíve also never heard of the notion that the hub shaft has become over sized, haha. Generally the size of the hub shaft remains a constant...haha. Itís jusy that the bearing has mangled itself and separated.
    Get the numbers off the thing and just order new ones.
    Presuming itís not the ďsealed for lifeĒ (that arenít really) alko type hubs ? They are a little more involved
    Good luck.
  4. #4
    Join Date
    Mar 2004
    Posts
    5,965
    k, these are new sealed bearings, put on by the same yard about 2 months ago.
    assuming the castellated nut is done up tight enough there is just no way the wheel can come off, however loose the bearing is fitted ??
  5. #5
    Join Date
    Feb 2010
    Glasson Dock
    Posts
    2,738
    Inflate the tyres much higher than they should be and when turning tight circles there is less drag and easier to turn.
  6. #6
    Join Date
    May 2005
    up on the moors.
    Posts
    33,220
    Are the front wheels articulated in some way , or are you dragging the trailer round a corner by main force ?
    I'd be inclined to cut the stub axles off and replace with new ones with a thread and nut on the outer part, so that you can be sure of reliability, and standard easily bought replacement bearings.
    Do you chock the trailer up ov er winter with the boat on it ? That takes the load off the tyres and bearings. A bearing with rings softer than the balls can form runnels with wind-caused vibration on the boat, and the rings and shoulder can distort.
    I think, therefore I am. I am, therefore I sail.
  7. #7
    Join Date
    Oct 2007
    Belgium
    Posts
    4,793
    Quote Originally Posted by simonfraser View Post
    this is completely correct, we had exactly the same with our trailer after multiple replacement of the bearings in the hubs,
    we nearly loast a wheel on the motorway, and after refitting everything in place (including the metal clips) the hub came nearly off the again when manouvring from the parking lot (strong sideway forces on the wheel)
    using loctide is a very unpredictable solution, so imho unreliable solution,
    we replaced the hubs with new, including new bearings fitted from the factory..
    ours were KNOTT,
    the parts are not expensive, and available online
    this is in Holland, but you mightb have similar in UK,
    https://www.aanhangwagendirect.nl/re...t-remtrommels/
    they have KNOTT, ALKO and BPW,
    this advice came after contacting the manufacturer,
    Harbeck, a reputated german trailer maker. !
    our trailer is a twin axel, 3500kg max weight, bought new in 2008,
    we used to use the trailer a lot, travelled all over europe, with our twin diesel 28ft boat !
    I still have the trailer and boat, and replace the hubs & bearings every two year,
  8. #8
    Join Date
    Mar 2004
    Posts
    5,965
    Set of wheels either side, 5cm space between them. So yes, torque on that lot for sure.
    So it is just the circlip holding the hub / bearing on ?!
    That makes not sense to me, yet.
    The studs keep the wheel on the hub.
    What does the castellated nut do then ?
    How important is the tight fitting of the bearing in the hub for yard work ?
  9. #9
    Join Date
    Oct 2007
    Belgium
    Posts
    4,793
    this was exactly our question at that time,
    it turns out that the clips are there just for security on the road, but they didn't hold the bearing in place during manouvring
    the main force for holding the bearing in place is by the tight fitting.
    In your case, if you replace the hub& bearings, you can use them in the yard for many ears,
    even if there is a lot of corrosion inside,
    at least they stick on the shafts
    or you could try to "weld " the old bearings in the hub
  10. #10
    Join Date
    Mar 2004
    Posts
    5,965
    Quote Originally Posted by BartW View Post
    K, so if the bearing is not a tight fit in the hub, it slides out and the wheel comes off. Understand that now.
    But, why ??
    Why does the castle nut not keep the wheel on ??
    And the inner part of the bearing is loose on the shaft anyway, so what difference does a tight outer fit make ??
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
