Results 1 to 3 of 3
  1. #1
    Join Date
    Apr 2019
    Posts
    1
    Default Eberspacher Hydronic
    I have an Eberspacher Hydronic heater on my boat for the past two years. Recently it stopped firing up, I dismantled it and reassembled it started up ok. I did not repair anything just measured voltages. After a day it refused to fire up again. This time I just tapped the housing with a spanner and it fired up. I have ordered a new controller but I don't think that that is the problem. Has anyone experienced this problem.
  2. #2
    Join Date
    Jun 2013
    Posts
    3,135
    Default Re: Eberspacher Hydronic
    I had a car with a starter motor like that. I used a hammer, but same thing Something is sticking. I don't know enough about how they work but the only thing I can think of that might stick is the inbuilt water pump. Maybe strip it down again and look for wear.
    If found in the Brexit forum, please return to the real world.
  3. #3
    Join Date
    Aug 2017
    Posts
    82
    You may have partially cleared the small filter on the inlet to the pump when you dismantled the unit. It clogs fairly easily unless you have another filter upstream and external to the hydronic. Good luck.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
