Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 51
  1. #1
    Join Date
    Mar 2014
    Bristol
    Posts
    449
    Default Halyard Wrap - Installing a Fairlead
    ok, so new to me boat seems to be suffering halyard wrap and a look through binoculars suggests the halyard is missing a fairlead. It is a Facnor furler and the instruction manual makes reference to a halyard deflector wheel - I believe this may have broken off, who knows, but it doesn't seem to be there.
    What size rivet's would I need to fix a fairlead up there? Can they be small enough to be installed with a regular rivet gun?
  2. #2
    Join Date
    Sep 2001
    Home - Sothampton, Boat - Gosport
    Posts
    9,779
    Default Re: Halyard Wrap - Installing a Fairlead
    If I've understood the system correctly, the deflector wheel fits on the forestay. I don't know what you're planning in the way of a fairlead, but it would have to be pretty meaty. As for installation, I reckon 5mm rivets should be fine provided the load in in sheer, not trying to pull them out.
    One common cause of wrapping is too much slack, either in the halyard or the forestay. If you've got a decent angle (7 deg or more), getting the tension right on both should be all you need.
    Steve
    Never believe anything until it has been officially denied.
  3. #3
    Join Date
    Jan 2003
    Clyde
    Posts
    7,282
    Commonly know as a halyard diverter. I've just fitted one when my mast was down as my doughnut was get a bit worn and not sitting perpendicular to the stay. I used 4.8mm monel rivets but I have decent rivet gun. It's a tough job up the mast with a small hand rivet gun.
  4. #4
    Join Date
    Aug 2011
    On the Celtic Fringe
    Posts
    13,894
    On the last boat I had a deflector wheel. Not impressed when the forestay went twang as I was getting the genoa off the foil at the end of the season. Would never have one again.
    Cynical Scottish almost retired engineer.
  5. #5
    Join Date
    Oct 2002
    Chichester
    Posts
    792
    I did this job on my 8.5 metre boat some years ago. The mast mounted fairlead had been fitted with Ali rivets and they let go (after several years!). I refitted the same fairlead with monel 5mm rivets. A normal hand riveter did the job, although it was very hard on the hands. I had the mast down, too.
  6. #6
    Join Date
    Nov 2004
    West Mersea. north Essex
    Posts
    4,785
    A halyard diverter/deflector is certainly what you need. The force on the rivets is quite extreme and NOT in shear. You need very meaty rivets. After some years of use, our diverter tore at the rivet and had to be replaced
    davidej
  7. #7
    Join Date
    Jan 2003
    Clyde
    Posts
    7,282
    Quote Originally Posted by Sandy View Post
    They are just a bit of light plastic, how did that affect the stay?
  8. #8
    Join Date
    Mar 2009
    Chichester Harbour
    Posts
    377
    Agree with stemarís comment. My yacht does not have a particularly good angle for the genoa halyard to mast sheave. But I keep a close eye on the genoa halyard tension and the top and bottom furler bearings run nicely (Harken). I am wondering if having this nice free running furler perhaps has avoided any genoa wraps (touch wood). I my first year of ownership I realised that too much tension and the sail is difficult to furl and too loose and it soon could see there was a small risk of halyard wrap. Looking at my yacht it is obvious that a loose genoa could result in a wrap. Hauling on the backstay effects tensions and the Harken manual mentions that care is needed to avoid stressing the bearings too much by having the genoa halyard firm then easing what was a tight back stay.
    Once I moveed the genoa down towards the deck slightly with a short strop at the top of the foil, but then was even more careful with the genoa tension. Any new short luff furling genoa i buy would have an extension of the tape at the top rather than a strop to make up the distance.
    Having owned a yacht in the past with hank on sails I do often think they have their merits on a smaller yacht.
  9. #9
    Join Date
    Jul 2011
    Levington
    Posts
    673
    Quote Originally Posted by steveej View Post
    That was the first job we had done on our SO 32; had a deflector wheel fitted to cure the halyard wrap; been fine ever since fingers crossed
    Yacht: White Pearl - Jeanneau Sun Odyssey 32i
  10. #10
    Join Date
    Nov 2008
    Posts
    6,795
    The diverter fitted to my boat had been fixed with setscrews tapped into the mast. They pulled out, and I replaced them with a new diverter fixed with 6.4mm monel rivets. I took the mast down for that and other jobs.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
