Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    8,996
    Default Re: Shout out for some help - Burnham on Crouch
    In spite of what they are telling you my coppercoat failed the first time. They blamed the fact that I had done it in cold (warmer than you will get this weekend) & there was a lot of condensation
    They supplied another lot of coppercoat at a reduced cost & I had to do it all over again (still does not work)
    This season I have to do the keel again due to rust coming through
    NO WAY would I consider doing even a small amount in the current temperature conditions
    As for only 2 of you- no problem. Do what I did both times. Leave the keel & rudder & points where the supports go. Then do those another day
    I also found that 3% thinners helps a lot. The area that I applied thinners ( the keel) works better than the hull where I did not use thinners The keel was done in warmer weather & works better so it may be a factor as swell
    Brushing is not successful. You need loads of rollers.
    But in any event - do not do it yet
    It is all down to the fact that my wife does not understand me !!
  2. #12
    Join Date
    Sep 2010
    Living near Saffron Walden, sailing out of Burnham on Crouch
    Posts
    95
    Thanks for all the advice above.
    We abandoned this a couple of weeks ago with the deteriorating forecast - but hoping to do this tomorrow on Saturday. Seems once again I've been left a person short - again I know this is cheeky and last minute notice but if anyone in the Burnham on Crouch area is free tomorrow (around 11am for 3-4 hrs) I'd really value some help. Can pay a small amount and stand you a fish supper and beers at the end.
    Here's hoping!
    Thanks,
    Phil
  3. #13
    Join Date
    Sep 2010
    Posts
    95
    Ignore the above - all sorted now!
  4. #14
    Join Date
    Jul 2005
    Posts
    533
    And result, all went well? Just wander, did you put any primer? I am about to do coppercoat very soon, on similar size of boat in Burnham as well, Thanks
  5. #15
    Join Date
    Sep 2010
    Posts
    95
    Quote Originally Posted by Shamaya View Post
    Only time will tell if it went well! No primer on the hull - just the protocol as recommended (blasted and then sanded). Keel sanded back and primed and then coppercoated.
    The real test will be November when she comes out.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
