Results 1 to 8 of 8
  1. #1
    Join Date
    Sep 2014
    Posts
    246
    Default Best epoxy for wood
    I hear some woods repel exoxy.
    Whats is the best epoxy to bed a stainless steel pin into iroko wood?
    Thanks for your input.
  2. #2
    Join Date
    Jul 2009
    South Wales and Bristol Channel, UK
    Posts
    2,427
    Default Re: Best epoxy for wood
    I never had any problems with West epoxy, but I always clean both surfaces with acetone before applying epoxy.
  3. #3
    Join Date
    Apr 2018
    Mooring, Faro
    Posts
    1,268
    For small quantity, nothing wrong with Araldite. For strong bond, I would put a couple of light saw cuts in the pin to give it a key.
  4. #4
    Join Date
    Nov 2010
    Solent
    Posts
    3,031
    Quote Originally Posted by CAPTAIN FANTASTIC View Post
    + 1 use it all the time Just be very careful to use exactly the right quantities and adhere to the working time.
  5. #5
    Join Date
    Jan 2004
    Bricks & mortar: Italy. Boat: Aegean
    Posts
    10,411
    Quote Originally Posted by STOL71 View Post
    The repelling is more to do with getting "fish eyes" when coating wood which is naturally oily or just dirty with grease/oil.
    Bonding a tiller-pilot pin into a hole, which I assume from an earlier thread is what you're doing, it's barely relevant.
    All epigrams are false
  6. #6
    Join Date
    Mar 2008
    Argyll
    Posts
    6,140
    Its a wee job and it sounds as if you still have to buy the stuff, I would go with Graham in post 3 and use Araldite, easy to obtain, to mix and apply, viscous enough to stay in place without the need to add a thickener, not overly temperature sensitive, blends with wood, strong and weather resistant.
  7. #7
    Join Date
    Feb 2007
    Essex
    Posts
    21,526
    I've never had any trouble with Araldite for small jobs such as bedding an Autohelm pin into a tiller.
    Far away is near at hand in images of elsewhere
  8. #8
    Join Date
    Feb 2004
    Boat: Portsmouth, Us: Stewkley
    Posts
    2,981
    Might be worth bringing the tiller indoors so it's a bit warmer. The Araldite will be thinner and soak into the wood better. Mind you it will go off quicker! A lot cheaper than buying bottles of epoxy!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
