Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Sanitation hose
  1. #1
    Join Date
    Sep 2004
    Surrey/Kent borders
    Posts
    880
    Default Sanitation hose
    Iím just about to replace all the sanitation hoses from both heads to the holding tank as well as both inlet hoses. Iím looking for any recommendations for the hose please as I only want to replace them infrequently. Also lack of smell and ease of fitting are important. Thanks in advance for any recommendations.
    We're all in the same boat......some of us have just been aboard a little longer.
  2. #2
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    18,302
    Default Re: Sanitation hose
    The grey Seaflow stuff sold by ASAP supplies is very good, much better than the white hard-plastic stuff I replaced.
    https://www.asap-supplies.com/sanita...anitation-hose
    Richard
  3. #3
    Join Date
    Nov 2007
    Boat Orwell - Me Norwich
    Posts
    7,284
    Quote Originally Posted by RichardS View Post
    Richard
    Agree. Well worth the additional cost.
    This type of butyl hose (other brands are available) also has the advantage that it's much easier to get onto fitting barbs (often difficult in larger bore hoses) than standard hose. So much so I've sometimes used it for non-sanitation purposes (e.g. deck drains, bilge pump outlets) where access is restricted.
  4. #4
    Join Date
    Feb 2019
    The Known Universe
    Posts
    593
    Used the Hard plastic stuff , as price difference was considerable from the sanitation hose, I plumbed in 2 toilets running to holding tank and holding tank out, 38mm , it bends ok to get round most corners but not as flexible as the hose.
    Double clipped and have had no issues or smells.
    To cut is a job a good hacksaw , as the wire is the tube needs a little more grunt.
    https://www.asap-supplies.com/sanita...er-hose-507038
    To be honest I would have used the hose recommended above , but In a tight Scots man who could not bring himself to spend that much money on my bodily fluids
    Flying birds have no master
  5. #5
    Join Date
    Nov 2007
    Live: Cascais, Portugal; Yacht: Wemeldinge, NL
    Posts
    930
    Quote Originally Posted by FlyingGoose View Post
    I think that's as close as you'll get to a Scot saying it is worth paying more to get the better stuff. I would agree with him!
  6. #6
    Join Date
    Apr 2016
    Chichester
    Posts
    688
    I recently plumbed in a new holding tank and replaced all the existing toilet hoses. I used the standard white sanitation hose for any visible pipes and the expensive butyl stuff for sections of hose hidden behind panelling where there were tricky bends. There are pros and cons to each.
    White pros: cheaper, easier to wipe clean, smaller outside diameter, looks proper.
    White cons: much harder to bend.
    Butyl pros: much easier to bend without heating and to slip over fittings.
    Butyl cons: more expensive, cloth cover not easy to keep clean, larger outside diameter, looks industrial.
    My butyl hose covering ended up with a fair amount of my blood on it but that's another story. The point is, it couldn't be wiped clean.
  7. #7
    Join Date
    Sep 2004
    Surrey/Kent borders
    Posts
    880
    Thanks to you all. Sounds like I need to start saving, buy butyl and use gloves when fitting it.
  8. #8
    Join Date
    Jun 2017
    Posts
    253
    Richard
    Good God that is expensive for a piece of pipe 1 metre long.
  9. #9
    Join Date
    Jan 2006
    Bristol
    Posts
    671
    Quote Originally Posted by Sea-Fever View Post
    Agreed, but having spent the best part of an hour trying to get a white plastic waste outlet hose onto the tail of my skin fitting, and subsequently buying the butyl one - where fitting took 3 mins (with some help from an exhaust pipe expander), I reckon it's money well spent.
  10. #10
    Join Date
    Nov 2009
    Posts
    18,302
    Quote Originally Posted by Poey50 View Post
    I do agree that on runs where the butyl hose is visible it does look rather industrial with that white stripe and red writing. However, I soon discovered that because it is flexible it was possible to spin in around so that the white stripe is hidden away on the "far side". All you can then see is the grey pipe which is not too ugly.
    Richard
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
