Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
  1. #1
    Join Date
    Jan 2004
    Med
    Posts
    5,689
    Default Time to think about motor boat
    We been sailors for some 40 years , part of that full time livaboards and it's getting close to the time when we always said one day we buy a motor boat and explore the rivers and canals of Europe .
    So here our problem , we know nothing at all about motor boats ,
    Except they like to drink fuel .
    So the question is , our interest would be in a good sea going motor cruiser ,
    Most import,
    12 mts or under that comfortable to live on full time ,
    With good cruising speed and not going to bleed us dry when it come to fuel .
    I know this is a bit like how long is a bit of string , but we have to start some where .
    Thanks guy for ny Input .
    Warning forumite dyslexia near by
    www.bluewatersailorcroatia.webs.com
  2. #2
    Join Date
    May 2001
    ation, Loc: ation, Loc: ation.
    Posts
    15,703
    Default Re: Time to think about motor boat
    Budget?
  3. #3
    Join Date
    Nov 2001
    Medway
    Posts
    19,496
    Regards fuel on non tidal waterways/canals , my two previous boats, a Princess 33 and a 37 ft Broom consumed around 1- 1.5 gallons an hour at 8 kph.
    Both had twin basic 130HP diesels and were perfectly capable on getting over Le Manche under their own steam.
    Would suggest for long term cruising, interior volume would be the first priority.
    Broom does come to mind along with some of the Dutch steel stuff .
  4. #4
    Join Date
    Sep 2016
    SoF
    Posts
    8,055
    If you are looking for an inland waters boat that you leave permanently on the continent then an ex-hire boat are usually good value
    Neither a Leaver or Remainer be
  5. #5
    Join Date
    Jan 2004
    Med
    Posts
    5,689
    Quote Originally Posted by Bouba View Post
    Not just inland , we still plain to use it out at sea .
  6. #6
    Join Date
    Jan 2004
    Med
    Posts
    5,689
    Quote Originally Posted by petem View Post
    Budget?
    Budget ? Depend , but we not looking at over 80k
  7. #7
    Join Date
    Jun 2002
    Posts
    2,749
    For your intended use an aft cabin boat such as a Broom, Haines, Westwood etc would be ideal. Plenty of options if you go for a Dutch steel boat.
    Noting that you say that you know nothing about motor boats, one thing to bear in mind is that they have different hull forms that vary from planing (no keel and props are the lowest point) to semi-displacement (usually have a keel that will be slightly lower than the props) and displacement (again, keel likely to be lower than the props). If you are doing mainly inland then semi-displacement or displacement is the way to go as there will be some protection for stern gear. Planing hulls combined with big engines give speed at sea. Semi-displacement hulls give some speed at sea but usually with higher fuel consumption. Displacement will not go above hull speed. As a rule of thumb if you want speed at sea you can work on getting circa 1 to 2 mpg. Obviously a lot better if you stay at or below hull speed. Overall, semi-displacement may be the appropriate compromise for your plans and Broom built many boats with people like you in mind.
    Several examples of what might be suitable on the market at https://www.nya.co.uk/boats-for-sale/
  8. #8
    Join Date
    Mar 2004
    Posts
    5,925
    'we buy a motor boat and explore the rivers and canals of Europe'
    unlikely to go on the plane / or be at sea much. buy it for the above use.
  9. #9
    Join Date
    Jan 2004
    Med
    Posts
    5,689
    Quote Originally Posted by Greg2 View Post
    Thanks that helpful , it's more info like this would be great
  10. #10
    Join Date
    Jan 2004
    Med
    Posts
    5,689
    Quote Originally Posted by simonfraser View Post
    You missed the important part , a good sea going motor cruiser , or are you saying there not a motor boat that will do both jobs ?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
