Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Join Date
    Apr 2005
    Looking out of the window
    Posts
    13,858
    Default 45ft ish catamaran owners: a question about fuel consumption
    Can I ask anyone with a reasonably recent mid 40s cat some questions about motoring:
    Is it possible to comfortably motor at Hull speed or just above (7-8knts)
    Do you tend to motor on one engine or does the turning force mean it’s better to use 2?
    What sort or fuel burn do you see at a decent speed (7-8knts)
    What sort of size fuel tanks do most cars this size have
    Thanks in advance
    Free supercharging Tesla referral code http://ts.la/jez9763
  2. #2
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    18,609
    Default Re: 45ft ish catamaran owners: a question about fuel consumption
    My 40 footer will do 7 knots but I wouldn't say that it's comfortable as that's around 3000 rpm which is well above what I cruise at. I would guess that a 45 footer will be a lot more relaxed at 7 but I think 8 will still be quite boisterous.
    I don't usually motor on one engine although I have done so when I've had a technical problem. I can't say that either I, or the autopilot, notice any difference except that it's slower.
    I haven't really checked fuel but it seems to be economical. I've got two 175 litre diesel tanks.
    Richard
  3. #3
    Join Date
    May 2003
    Eastern Atlantic seaboard
    Posts
    2,990
    Crossed the pond last year on a 50' Lagoon with 2 x 80hp Yanmars. There was a marginal advantage in fuel economy running one engine to maintain 5.5 knts, burning 6l/hr.
    During the run-in from Bordeaux to Cascais using max revs a lot we burnt up to 16l/hr giving 8.5knts through the water. Ouch! A 4 figure fuel bill for a 600 mile trip. How I pity moboers.
    I'd rather be tethered to a pad eye than tethered to an iPad.
  4. #4
    Join Date
    Apr 2005
    Posts
    13,858
    Ok thanks.
    Do sensible cruising speed should be more 6-6.5knts from a fuel burn POV.
    80Hp motifs sounds sporting - I think the upgrade for one of the cats I’m idly considering is 57Hp, standard I think is 40-45Hp
    In my current 50ft boat at 8 knots we burn about 32l/hr. let’s not discuss 20knts....
  5. #5
    Join Date
    Jan 2004
    Med
    Posts
    5,676
    Quote Originally Posted by Whitelighter View Post
    Ok thanks.
    32 LPH ?? , am I reading that right ?
    Warning forumite dyslexia near by
    www.bluewatersailorcroatia.webs.com
  6. #6
    Join Date
    Dec 2010
    South Oxfordshire, Gosport and Wellington New Zealand.
    Posts
    7,748
    We have a single 110 HP Turbo Yanmar in our 12.5 metre motorsailer.
    Over the last 4,000 NM we have averaged just under 4 LPR. Usually with some assistance from the sails.
    2,200 RPM-my prefered cruising RPM if the wind will not serve- 3.2 LPH.
    But, thread drift, as not a 45 foot cat................................
  7. #7
    Join Date
    Feb 2017
    Türkiye
    Posts
    1,493
    More drift but my 10.3M motor cat has 2 x 75HP Yanmars. I motor almost exclusively on one engine doing 7 Knts @ 2200 rpm and burning 3.5 lph. If I employ both engines @ 2200 she makes 8.5 Knts for double the fuel burn.
  8. #8
    Join Date
    Apr 2005
    Posts
    13,858
    Quote Originally Posted by sailaboutvic View Post
    Yes. You are reading that correctly
  9. #9
    Join Date
    Apr 2005
    Posts
    13,858
    Quote Originally Posted by Irish Rover View Post
    More drift but my 10.3M motor car has 2 x 75HP Yanmars. I motor almost exclusively on one engine doing 7 Knts @ 2200 rpm and burning 3.5 lph. If I employ both engines @ 2200 she makes 8.5 Knts for double the fuel burn.
    Well not total thread drift. Still useful info thanks
  10. #10
    Join Date
    Jul 2009
    Winter in Falmouth, summer on board Rampage.
    Posts
    5,032
    I moved a 42 foot Fontain Pajiot cat from Lefkas to Barbados winter before last. When motoring it was normally at about 6.5 knots on two 30 hp engines running at 2200 rpm: that burnt about 4-4.5 lph. As above, running on one engine meant running it at about 2600-2800 rpm with a boat speed of 5.5 knots: no noticeable handling problems (did a fair bit of one engines running as we had diesel bug problems that often knocked out an engine....).
    The cat had a 600 litre diesel tank. I also carried 200 litres in jerrycans on the leg from Tenerife to Barbados: didn’t actually need them as we arrived with 300 litres left.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
