Results 1 to 4 of 4
  1. #1
    Join Date
    Aug 2012
    London
    Posts
    28
    Default VP 61A Fuel Lines
    Hi, a survey i have just had done has highlighted that although not currently a problem, i need to keep an eye on the fuel lines and will most likely have to change them, engines are 2 x TAMD 61A engines. Can anyone advise who is best to get them from
    many thanks
    Paul
  2. #2
    Join Date
    Mar 2016
    Posts
    930
    Default Re: VP 61A Fuel Lines
    Hi paul
    We have the same engines. What fuel lines do you refer to ? Or what fuel lines were picked up on ?
    You mean the HP lines from the pump to the injectors, LP lines from tank or anything in between through the primary or secondary filters ?
    The former are hard piped lines with banjo fittings etc. The latter are occasionaly variable depending on the boat.
  3. #3
    Join Date
    Apr 2009
    Posts
    220
    The same thing showed up in my survey. They recommended that the low pressure flexible fuel lines should be changed. They are a standard VP part and my local dealer said he can supply them but the are not cheap.
    I think ASAP do some also.
  4. #4
    Join Date
    Apr 2007
    midlands
    Posts
    7,186
    Quote Originally Posted by nav1 View Post
    many thanks
    Paul
    The volvopenta ones are silly money .
    You need 10mm Vetus hose ISO 7840 walled hose which is also suitable for inland waterways BSS certification.
    You can use the existing metal unions, just cut off the crumped unions to reveal the hose tail and union, use double hose clips . Job done .
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
