Results 1 to 9 of 9
  1. #1
    Join Date
    Apr 2005
    Looking out of the window
    Posts
    13,858
    Default Removing a corroded steering wheel on tender
    The wheel on our walker bay 340 has had it.
    The plastic coating is turning back to oil some how. Itís been on the boat on the boat for I guess 12 years and it looks pretty corroded. Iíve soaked it in WD40 and got the retaining nut of but it wonít budge.
    Before I test it multiple times with a hammer, is there a recognised technique for freeing a wheel from the shaft that might make it easier, quicker or just less likely to also bugger something else I havenít thought of?
    Free supercharging Tesla referral code http://ts.la/jez9763
  2. #2
    Join Date
    Jun 2011
    Volos-Athens
    Posts
    4,719
    Default Re: Removing a corroded steering wheel on tender
    the other thread on removing the wheel on a princess gives some ideas...
    I've had good luck with 3leg puller, tighten as much as you can and then a couple of good smacks with a heavy hammer, worked on MiToS wheels that were there for a good 30+ yrs...
    V.
  3. #3
    Join Date
    Sep 2005
    Brighton/Antibes
    Posts
    8,571
    Puller, hammer, heat if still won't let go.
  4. #4
    Join Date
    Apr 2005
    Posts
    13,858
    Thanks all.
    It’s a teleflex safe-t steering system. I’m assuming it’s a tapered shaft and not something more advanced.
    Will try boiling water next and failing that go hunt for a puller
  5. #5
    Join Date
    Jan 2009
    Stratford on Avon
    Posts
    11,071
    As JtB says, heat the boss with blow torch, then a couple of sharp taps with a mallet then pull.
  6. #6
    Join Date
    Mar 2002
    Posts
    17,096
    Quote Originally Posted by Whitelighter View Post
    That's my guess too, but I'd check carefully also the sides, just in case there's also a dowel pin somewhere.
  7. #7
    Join Date
    Apr 2005
    Posts
    13,858
    Got it.
    Some vicious blows with a hammer while a puller was under tension and it freed.
    New wheel arrives on Tuesday. Simple yet satisfying job
  8. #8
    Join Date
    Jan 2009
    Stratford on Avon
    Posts
    11,071
    Got it.
    Result, well done Jez!
  9. #9
    Join Date
    Jul 2003
    River Itchen, Southampton
    Posts
    6,789
    The plastic coating is turning back to oil some how. It’s been on the boat on the boat for I guess 12 years and it looks pretty corroded. I’ve soaked it in WD40 and got the retaining nut of but it won’t budge.
    Before I test it multiple times with a hammer, is there a recognised technique for freeing a wheel from the shaft that might make it easier, quicker or just less likely to also bugger something else I haven’t thought of?
    Glad the brute force and ignorance worked. If, in the unlikely event , you run out of either in future, freezer spray from a motor factors is worth a go.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
