Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Join Date
    Sep 2014
    Posts
    82
    Default 'Sta-Loc' fitting problem
    I've just bought a 7mm 'Sta-Loc' fork from a supplier in the UK (advertised as Sta-loc). This was about 10% cheaper than the nearest competitor, although still expensive. This came in an unlabelled, clear plastic bag, with no instructions. I have read that the fittings are supplied with instructions. There are no markings on the cone either, which seems a bit odd to me. I am now trying to fit this damn thing and it is proving extremely difficult. Basically, whatever I do, the cone is always forced out over the inner core when I try to wrap the outer wires. I am now wondering whether what I have is a genuine Sta-Loc, or some 'cheap' immitation. Anyone had a similar experience?
  2. #2
    Join Date
    Sep 2001
    Me - Zumerzet Boat - Wareham
    Posts
    12,064
    Default Re: 'Sta-Loc' fitting problem
    Lots of fitting instructions images and videos online.
    I used an artery clamp at the bottom of the inner core to hold the cone in place while wrapping the outer wires.
    MontyMariner.co.uk
    Facilitated by AWESEM WP Agency
  3. #3
    Join Date
    Sep 2014
    Posts
    82
    Yes, I've watched several videos and read several accounts, including on forums where people have been having problems. One of my main concerns is whether this is a genuine fitting or not. I'll try the artery clamp idea.
  4. #4
    Join Date
    May 2013
    Moray firth
    Posts
    24
    Hi Steve I think the important things are make sure the end of the wire is cut square leave enough I think it's 3mm past the end of the cone.Wedge the cone into the fitting so it's effectively held then screw the fitting together and allow the former to bend the outer wires into place. Youve probably read all the instructions watched the videos etc undo the fitting and check it's done up right. I think it's prefferable to screw the part that contains the former to the fitting rather than the other way around if that makes sense
  5. #5
    Join Date
    Sep 2014
    Posts
    82
    Hi Chewbacca
    The problem is, is that this is exactly what I am doing, but the cone just gets pushed off as soon as I move the threaded part of the fitting towards the wire end. Even if I try to forcibly hold it in place. Also, I am making sure that the wire does not fall into the split in the cone. Seems to me, that something is amiss somewhere.
  6. #6
    Join Date
    Jan 2003
    Clyde
    Posts
    7,308
    Try giving the cone a squeeze with some pliers once it's in place. Are you sure it's the right size for your rigging wire?
  7. #7
    Join Date
    Aug 2004
    Home East Lancashire boat Spain
    Posts
    4,570
    If its a fake then it may be like one I bought recently. The cones just squash the wire frm the outside.
  8. #8
    Join Date
    Sep 2014
    Posts
    82
    I was told that (by the people at Sta-Loc) that this must NEVER be done, although I have heard of some riggers doing this. I measured the rigging with a vernier gauge before ordering, so it should be OK. The cone seems to fit on very easily. Maybe too easily......
  9. #9
    Join Date
    Sep 2014
    Posts
    82
    What did the fake look like? The one I have bought looks like it is very good quality. I think it is the genuine article, but came in a plain plastic bag, with no instructions. This worries me. Where did you buy yours?
  10. #10
    Join Date
    Aug 2012
    Me: Wakefield; Boat: Gibraltar Point SC
    Posts
    193
    What about using a drop of loctite or superglue on the cone to hold it once over?
    David
    Red Fox 226
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
