Results 1 to 3 of 3
  1. #1
    Join Date
    Mar 2005
    Looe, Cornwall
    Posts
    246
    Default MPPT Solar Controller for 12v and 24v systems
    This is a high-quality Emponi brand German-made MPPT solar controller that can handle up to 6 amps (100W of solar panels).
    Uniquely, this regulator can charge both 12V and 24V systems from 12V solar panel(s). You do not need to wire your solar panels in pairs if you have a 24V system!
    Includes a built-in polarity tester and status feedback LED.
    On average you should get around 15-20% more power from your solar panel using a SOL1 compared to a conventional regulator. But when it really matters - in dull, overcast conditions, or when your battery is flat - the increase in output can be as much as 30%.
    Solar panel voltage: min 12V max 20V
    Solar panel output power min 20W max 100W
    Battery bank voltage: 12V / 24V
    Battery bank size: min 20Ah, no max
    Operating temp: min -20C max 45C
    Terminal connections: 1.5 mm2
    25 incl postage.
    Changeman
  2. #2
    Join Date
    Jan 2011
    Posts
    105
    Default Re: MPPT Solar Controller for 12v and 24v systems
    Yes please to this and the relay.
  3. #3
    Join Date
    Mar 2005
    Looe, Cornwall
    Posts
    246
    Dave
    Have pm'd you
    Changeman
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
