Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Join Date
    Mar 2002
    Posts
    17,255
    Default Re: Elba to Ponza - any advice on stop offs along the way
    Quote Originally Posted by Hooligan View Post
    Hopefully mastered it!
    You sure did, congratulations!
    Btw, I see that you used the website I mentioned, i.e. imgbox, whose pros and cons I'm by now familiar with.
    And one of its (very minor, in fairness) cons is that the links it generates automatically are a bit weird, because they include the "URL" tag, whose only purpose is to make the image a clickbait.
    In practice, for the above image you used the following sentence:
    [img]httpsː//images2.imgbox.com/c7/6c/udMSZWJ6_o.jpg[/img]
    Which is 100% correct, and shows the following image as a result.
    Otoh, if you would have copied the automatic link generated by the imgbox website, the sentence would have been as follows:
    [urI=http://imgbox.com/udMSZWJ6][img]httpsː//images2.imgbox.com/c7/6c/udMSZWJ6_o.jpg[/img][/urI]
    Note that the central part included in the "IMG" tags is exactly the same as above, and is the one that actually does the job.
    The rest (which I grayed out) is what makes the image itself an hyperlink: the result looks the same, but if you click on the previous image nothing happens, while the one below redirects you to imgbox website.
    ...with apologies if this is just a complicated way to confirm that you already did the perfectly right thing, but just in case you should wonder why imgbox automatically suggests something different!
  2. #22
    Join Date
    Jan 2019
    Hampshire
    Posts
    55
    It was trial and error but I also figured that in the Links only box i had to click full size then copy the link and add the IMG etc.. then use the advanced box to preview if needed. But seems to work
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
