Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Dec 2002
    Gloucestershire
    Posts
    5,135
    Default Workzone (Aldi) 1800 w generator
    Two points.
    I have an in-built Sterling charger. They do not seem to get on. I guess it could be something to do with the waveform. I can't find my 'scope to check.
    Can anybody identify the battery charging outlet plug please?
    I'd rather be naked
    www.mastaclimba.com
  2. #2
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    18,295
    Default Re: Workzone (Aldi) 1800 w generator
    Is this another one of those threads where you drip-feed us further information as we go along?
    Richard
  3. #3
    Join Date
    Jul 2009
    South Wales and Bristol Channel, UK
    Posts
    2,429
    The Aldi battery chargers don't like the Workzone generators either; I know from experience!!
  4. #4
    Join Date
    May 2005
    up on the moors.
    Posts
    33,062
    Alas, RS, it seems that your elite driving skills are more advanced than your support ones....
    Graham, dunno if this is the model of your generator but there are some Youtube videos of Aldi kit.
    Here's a screen dump of one of them, showing the cigarette lighter style 12v socket.
    My Honda genny has an 8 amp 12v socket which looks like the old caravan 12v sockets, with two slots at right angles.
    Other 12v socket configurations exist.
    I think, therefore I am. I am, therefore I sail.
  5. #5
    Join Date
    Nov 2009
    Posts
    18,295
    Quote Originally Posted by sarabande View Post
    Be patient Sarabee, Graham will drip-feed us a picture of his particular gennie soon enough .... and your guessing will be over.
    Richard
  6. #6
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    43,052
    Quote Originally Posted by Graham_Wright View Post
    Two points.
    Is this not explained in the manual ?
    It is the socket labelled 12V DC. It will probably make a poor battery charger though which is why it is usually suggested that a mains voltage charger should be used .
    Here is a link to the video from which I guess Sarabande took the screen grab
    https://www.youtube.com/watch?v=PyHr3TsPk18&vl=en
    Dont forget to earth the device.
  7. #7
    Join Date
    Dec 2002
    Gloucestershire
    Posts
    5,135
    Quote Originally Posted by VicS View Post
    Sorry - insufficient information as usual.
    It was the type of socket not its identity (which is clearly labelled). It has two flat pins at 90 to each other separated vertically (identical to the second picture in #4). It claims to chuck out 8 amps but bodging a connection inside was not very special.
    I have read elsewhere that the output is a pretty pure sine wave so Mr Sterling should be happy.
    The strange thing is that the charger has three outputs which I have fed through three breakers. Switching on a 12 volt output loads the genny which then picks up. Switching on a second output breaker again loads the genny but the breaker trips out.
    I now have a simple dumb charger on board that is doing a good job but I would like to understand and maybe fix the apparent Stirling problem. It worked ok on shore power but then it was really only trickle charging.
    This is the genny;- https://www.aldi.co.uk/workzone-petr...96344208706700
    I'd rather be naked
    www.mastaclimba.com
  8. #8
    Join Date
    Nov 2009
    Posts
    18,295
    Richard
  9. #9
    Join Date
    Jan 2016
    Ipswich & Southwold
    Posts
    1,392
    I have one of these cheapies for running bits and pieces on site to save lugging my big diesel Stephill about. It outputs a pretty much pure sine so should work with a Sterling switch mode power supply.
    What are the symptoms?
    Electrician In Ipswich & Southwold Yard
    Custom Panels, Eberspacher/Webasto, ECU Remapping
  10. #10
    Join Date
    Dec 2002
    Gloucestershire
    Posts
    5,135
    Quote Originally Posted by matthewriches View Post
    As in #7.
    I'll give it another go today.
    I'd rather be naked
    www.mastaclimba.com
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
