Results 1 to 8 of 8
  1. #1
    Join Date
    Jul 2008
    East coast UK. Mostly. Sometimes the Philippines
    Posts
    8,244
    Default Storage of dry suit zips
    Years ago I bought an “offshore” type drysuit. It parted company with its instructions within hours. I’ve just read something which says I ought to store it with the zipper undone. ..
    ... I never have. ..
    Umm.
  2. #2
    Join Date
    Jan 2006
    West Yorkshire
    Posts
    1,356
    Default Re: Storage of dry suit zips
    Strange, both my diving drysuits are always stored with the zip done up, and my kayaking one was the same.
    Zips lubed regularly and, famous last words, never had any issues.
    Custom engineering for marine & dive use; http://ffsystems.co.uk
  3. #3
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    21,457
    I was told many years ago that such things should be stored with the zip undone because when folded a fastened zip is fairly rigid and will be damaged, whereas an unfastened zip is quite flexible.
    Answers to some technical queries at new website http://coxeng.co.uk
  4. #4
    Join Date
    Mar 2010
    52 43N 004 03W. ish.
    Posts
    354
    Whether you leave the zip open or closed(open for me,30 years using and maintaining drysuits amongst other things)leave a few inches travel until the end stop.This makes it easier to free off the slider if it becomes stuck.
    Cheers
    "whatever floats your boat,on whatever boat you float"
  5. #5
    Join Date
    Oct 2001
    Surrey & boat in Dorset. Both have pubs
    Posts
    3,648
    Quote Originally Posted by caiman View Post
    Cheers
    I found out the hard way about this many years ago !
  6. #6
    Join Date
    Oct 2014
    Australia
    Posts
    177
    Quote Originally Posted by Minn View Post
    Umm.
    The reason is simple. The matching sealing lips are compressed when the zipper is closed. With time, the deformation becomes permanent and there is less pressure keeping the lips together. When stored opened, the lips retain their original shape and seal more reliably after you close the zipper.
  7. #7
    Join Date
    Jul 2008
    Posts
    8,244
    Quote Originally Posted by jiris View Post
    Thank you.
    I’m going to do that from now on.
    Also, mindful of Caiman’s point, from now on I shall treat drysuit zips like gate valves - open, then back off a little, and give them “regular exercise”, by opening and closing them all the way regularly.
  8. #8
    Join Date
    Dec 2001
    Grenoble
    Posts
    27,957
    Thank you.
    A block of wax rubbed along the zip helps.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
