Results 1 to 6 of 6
  1. #1
    Join Date
    Feb 2018
    Posts
    84
    Default TAMD 73P EDC- why is there always something?
    Hi everyone
    Engines are running well. So why the post...
    Today, I could only start the port engine from the fly bridge. No neutral light at the lower helm, although the starboard is unaffected. No error codes (1:1).
    Starts fine from the bridge. No starting of port engine nor engine control from the lower helm.
    Do we think a faulty throttle unit? I have been messing about in the area beneath it (fitting electronics) but I can't see any connections that I would have knocked off - they all seem tight. Anything else I could do or check?
    In other news - I have a leak from somewhere up towards the turbo on the port engine (although it has had a new oil hose in the not too distant past). Why are these things always in the most inaccessible places?
    Thank you.
  2. #2
    Join Date
    Apr 2007
    midlands
    Posts
    7,186
    Default Re: TAMD 73P EDC- why is there always something?
    Quote Originally Posted by Solent Sailor View Post
    Hi everyone
    Thank you.
    Is the start operation on fly by key or button ?
    Sounds like a loom issue.
  3. #3
    Join Date
    Feb 2018
    Posts
    84
    It's keys at the lower helm and buttons on the upper.
  4. #4
    Join Date
    Apr 2007
    midlands
    Posts
    7,186
    Hi everyone
    Thank you.
    Do a lever calibration
  5. #5
    Join Date
    Jun 2010
    Home staffs Boat Mallorca
    Posts
    287
    Replace the bulb in the neutral light. On our targa 43 with 73s the filament of the bulb is effectively the earth for the relay it took me a while to suss out but replacing the bulb cured the staring problem
  6. #6
    Join Date
    Feb 2018
    Posts
    84
    Lovely weekend on the water, but still the same problem (although I've sorted the oil leak (I think)!)
    A lever calibration does solve the problem. Temporarily. Immediately after calibration, the engine will start, but if I switch off, then it seems to have lost its memory of the calibration and we're back to square one. Calibrate again, and it starts again....
    The neutral light comes on during/after calibration - so I can't see that the bulb could be the source of the problem - surely it wouldn't light at all if it was iffy?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
