Results 1 to 8 of 8
Thread: Teak oil.
  1. #1
    Join Date
    Mar 2007
    South of France.
    Posts
    4,043
    Default Teak oil.
    Bought a Beneteau Trawler back in the Winter ... they have a fair bit of teak capping rail around the cockpit and up the starboard side deck. The previous owner at some point has used teak oil on this which now looks awful! Any suggestions as to the best way, if there is one, of getting rid of it and getting the teak to look original again? Any help appreciated, thanks.
    _______________________
  2. #2
    Join Date
    Jun 2001
    In the far North
    Posts
    9,692
    Default Re: Teak oil.
    Either leave it to weather or sand the woodwork
    Claymore
  3. #3
    Join Date
    Dec 2010
    South Oxfordshire, Gosport and Wellington New Zealand.
    Posts
    7,737
    Quote Originally Posted by claymore View Post
    Oxalic acid solution, but keep it off bits you dont want bleaching!
    It will clean the teak up very well.
    International Woodskin will look ok for a couple of years before requiring redoing.
  4. #4
    Join Date
    Feb 2007
    Essex
    Posts
    21,739
    If you want the simple look, Patio Magic/Boracol could be used as well. It is often difficult to see how much discoloration is dirt and how much mould.
    Far away is near at hand in images of elsewhere
  5. #5
    Join Date
    Sep 2011
    Posts
    57
    I had a steel Ebbtide 33 With all the deck fittings mounted on teak blocks including the two toe rails total length70 ft that made a total of 93 separate items. I used a three stage process. first scrub with variety of brushes (large and toothbrushes) with soapy water to remove dirt, and then flushed with clean/ sea water if on mooring. Second use oxalic acid at 100% solution, only on teak flush off runs on the deck, then flush again with fresh/ sea water and leave to dry. last stage brush on Teak Wonder, using bare minimum and will be sucked up like blotting paper. This took two days if the weather was kind. Looked fantastic lasted almost the season. Then the same again next year. Alternatively once it is clean leave it to oxodise and go silver. It is up to you how much time and effort you want to expend to get that warm honey look.
  6. #6
    Join Date
    Apr 2007
    West Coast
    Posts
    2,242
    Best way. Also wash with water and softish brush across the grain. It will take a season or so but nature is best.
    Chris
    Out west.... (or in the office)
  7. #7
    Join Date
    Aug 2011
    On the Celtic Fringe
    Posts
    13,857
    Quote Originally Posted by rotrax View Post
    Or, in my experience, evaporated in under a season!
    Cynical Scottish almost retired engineer.
  8. #8
    Join Date
    Aug 2013
    SW Scotland
    Posts
    18,984
    Quote Originally Posted by Sandy View Post
    Mine went horrible in year. One third looked fine, one third fell off and one third allowed water penetration and turned black underneath. Teak Wonder is working very well for me now.
    "Seamen are always wanting to do things the proper way; and I like to do them my way."
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
