Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Join Date
    Oct 2018
    Falmouth, Cornwall
    Posts
    153
    Default Re: Any Perkins M90 or engine diesel mechs to advise ?
    I'm curious how they've diagnosed a non sealing exhaust valve before stripping or removing the head . In your first post you say you asked them to do a compression test - what was the result of that? A valve not sealing would show as low compression on that cylinder.
    As with Heckler, I'm also curious as to how this would over pressure the header tank?
    Andy
  2. #12
    Join Date
    Jul 2012
    Maderia, heading back to UK
    Posts
    77
    Finally back on boat , the compression tests were good, the work i had done in the canaries on the injectors was shoddy and was redone in Maderia, the main issue was blocking on the cooling system , heat exchanger etc this was cured by chemical cleaning of sea water circuit ( RYDLYME ) and at the same time a full backflush on the FW circuit, sea trial was yesterday over 1.5 hrs at 2100 rpm boat doing 7.5kts and every temperature was correct no more steam in the exhaust
    well done to Neptune Pirate in Maderia and their perkins mechanic for sorting it all out at a very reasonable cost.
  3. #13
    Join Date
    Jan 2011
    Posts
    5,575
    Quote Originally Posted by Gallant Spirit View Post
    So it was steam then. Almost always is.
  4. #14
    Join Date
    Nov 2001
    Eastern Med ish
    Posts
    3,264
    Quote Originally Posted by Bobc View Post
    probably condensate, steam is invisible to the eye
    never confuse education with intelligence
    Sailing the Aegean
  5. #15
    Join Date
    Jul 2012
    Posts
    77
    yup Steam (saturated lol ), have done a 500m trip with engine as a test to Lisbon no issues at all and my fuel economy is also a lot better
  6. #16
    Join Date
    Jan 2011
    Posts
    5,575
    Quote Originally Posted by rtboss1 View Post
    Pedant alert!
  7. #17
    Join Date
    Nov 2001
    Eastern Med ish
    Posts
    3,264
    Pedant alert!
    Sailing the Aegean
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
