Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
  1. #1
    Join Date
    Jun 2017
    Posts
    253
    Default Passage plans - resources
    It's probably not a bad thing for any skipper to sit down and consult the relevant sources 'from scratch' when devising a passage plan rather than rely on someone else's homework.
    However are there reliable sources from which the most common passage plans for yachts could be obtained??
  2. #2
    Join Date
    Jul 2008
    East coast UK. Mostly. Sometimes the Philippines
    Posts
    8,588
    Default Re: Passage plans - resources
    A vote for Roger Gaspar (aka “Tillergirl”)’s “Crossing the Thames Estuary”.
    It does exactly what it says on the tin. Comprehensive passage plans for all practical routes.
  3. #3
    Join Date
    Jun 2017
    Posts
    253
    Quote Originally Posted by Minn View Post
    Any Solent equivalent recommendations?
  4. #4
    Join Date
    Apr 2019
    Cornwall - top end :-)
    Posts
    79
    Quote Originally Posted by Sea-Fever View Post
    Or for the Southwest?
  5. #5
    Join Date
    Sep 2001
    Me - Zumerzet Boat - Wareham
    Posts
    11,973
    Yes,
    HW to LW go West
    LW to HW go East
    MontyMariner.co.uk
    Facilitated by AWESEM WP Agency
  6. #6
    Join Date
    Aug 2007
    Suffolk
    Posts
    5,081
    + 1, very useful for the Estuary.
  7. #7
    Join Date
    Jun 2017
    Posts
    253
    Quote Originally Posted by LadyInBed View Post
    Yes,
    HW to LW go West
    LW to HW go East
    Genius.
    Now all I have to do is work out when the tide is in.
  8. #8
    Join Date
    Mar 2014
    Bristol
    Posts
    449
    I've often found that internet searches turn up local yacht clubs with websites that have passage plans on them. It has worked for me a number of times, sort of local knowledge sharing but instant access once you have found it.
  9. #9
    Join Date
    May 2007
    Posts
    36,314
    Various pilot books?
    TBH, for the channel and Solent, what you need is a set of tide charts, Wight Hazards, Solent Hazards, Inshore along the Dorset Coast all by Peter Bruce, and Fishwick's West Country Cruising.
    T'other side, RCC Pilot books?
    More detailed info will allow you to get closer to the rocks, but mostly a simple passage plan based on studying the chart and alamanac will see you right.
    Going through the process for yourself is good, rather than borrowing a crib sheet.
    But I'll happily take the crib sheet and try to rationalise against the basics of chart, tide tables, tidal streams.
  10. #10
    Join Date
    Oct 2001
    Posts
    1,347
    If you are after a printed source, Reeds Almanac is a good one.
    But the tidal streams info is a bit coarse so some printed tidal stream booklets for your particular area are useful. Then you can write in the times for each page of the book and it then is obvious what gates there are, and optimum times to hit them, eg at slack water turning in your favour or whatever. Then you need distances between your start point, tidal gates or headlands (Reeds has some distance tables but a small scale passage chart will be better) and your estimated rate of progress and that will determine start times. But you might also have locks or cills or tidal estuaries at your start or destination. Reeds will have the data you need to work for all these as well.
    It all boils down to a plan that goes I need to start between this time and that, and get to particular points between this time and that, and so if I'm not making enough progress, then the engine needs to go on. Or divert to a convenient spot. Or accept its all gone Horlicks and plod on regardless .
    That's how I do it anyway.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
