Results 1 to 3 of 3
  1. #1
    Join Date
    Oct 2001
    Plymouth / South Hams
    Posts
    455
    Default Wind Speed/Direction - checking functionality
    I've got a Raymarine ST60 unit, the mast has recently been down for a re-rig and I kept the mast unit on board until it was re-stepped. Whilst the mast was down I did a basic clean of the connections at the masthead connector and put some petroleum jelly in to lubricate and reduce corrosion.
    The mast was re-stepped, the head unit reinstalled by the rigger and after wiring back up I'm not getting any display at the ST60 display.
    Is there a way of checking functionality by checking say voltages at the mast base and the display unit to ascertain whether it's the vane unit, the wiring or the display unit that are at fault?
    Not sure what else I could do to correct as the vane unit appears to be working well and certainly spun quite happily when it was off the mast so I dont think there are any bearing issues.
    All suggestions welcome as to what to do next
  2. #2
    Join Date
    Aug 2004
    Cumbria; U.K.
    Posts
    3,265
    Default Re: Wind Speed/Direction - checking functionality
  3. #3
    Join Date
    Oct 2001
    Posts
    455
    Brilliant, just what I wanted, thank you!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
