Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Aug 2009
    Scotland.
    Posts
    14,019
    Default A5 Plastic "Paper" Printing
    Hello,
    I was on a charter boat and they had instruction notices printed on a white plastic sheet, A5, matt finish, slight surface roughness, about 1mm thick tops, stiff. The ink gave a crisp and clear, colour fast text. The notices were for VHF procedure, for example.
    I have tried googling but failed to find something. It's probably really obvious! Does anyone know what I am describing, pic below?
    Thanks,
    BlowingOldBoots
    Notice by Rival Sailor, on Flickr
    "'...contradictions .... are deliberate exercises in doublethink." Orwell from 1984
  2. #2
    Join Date
    May 2001
    UK East Coast
    Posts
    35,503
    Default Re: A5 Plastic "Paper" Printing
    You can easily buy waterproof plastic paper for use with laser printers, either plain or adhesive-backed.
  3. #3
    Join Date
    May 2005
    up on the moors.
    Posts
    33,146
    Zecom paper. Several stockists.
    I used to use it for Dook of Embra work.
    Be slightly careful if you are printing many copies, as the laminate goes tacky if the printer roller become too hot.
    I think, therefore I am. I am, therefore I sail.
  4. #4
    Join Date
    Aug 2009
    Scotland.
    Posts
    14,019
    Thanks pvb, googling "waterproof plastic paper" was the phrase (obvious now), and one of the products is Toughprint which looks like the material in the picture.
    https://www.amazon.co.uk/Toughprint-...c=1&th=1&psc=1
    Thanks for the tip sarabande, only for light use.
    I'll buy a ream and see how it works out.
  5. #5
    Join Date
    Feb 2006
    Posts
    6,329
    Isn't that just an acetate sheet?
  6. #6
    Join Date
    Nov 2007
    Boat Orwell - Me Norwich
    Posts
    7,518
    Quote Originally Posted by BlowingOldBoots View Post
    Hello,
    I was on a charter boat and they had instruction notices printed on a white plastic sheet . . . The notices were for VHF procedure, for example.
    You need 500 sheets of instructions for your boat?!
  7. #7
    Join Date
    Nov 2007
    Kingdom of Fife
    Posts
    6,048
    Remember that most inkjet inks are water soluble. I have used them though with a sealing spray that worked well. For most things though the quick and easy solution is to laminate them, and you can get the pockets in many sizes
    Peter
  8. #8
    Join Date
    Jul 2006
    Posts
    4,699
    Any sign shop will print for you onto white glossy stickyback vinyl, in any colour you like (even colour photos). Same stuff as van graphics. Any size from A4 to side-of-a-quite-big-van. Doesn't fade (some of mine outdoors 13 years old).
    I also occasionally use A4 laser printer sticky-mylar sheets, but black on white only and a satin finish.
  9. #9
    Join Date
    Dec 2003
    Bangor Co.Down
    Posts
    733
    Buy a laminator
  10. #10
    Join Date
    Nov 2012
    Liverpool
    Posts
    444
    Quote Originally Posted by mdonnelly View Post
    Buy a laminator
    My laminator packed up (actually jammed because I put photos that were too thick through it!) so now I just use an iron.
    Enjoy your sailing,
    Jaguar 25
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
