Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    Join Date
    May 2005
    Loch Snizort, Isle of Skye
    Posts
    4,845
    Default Can you use your autopilot to lock the rudder?
    Thought this would be a simple question but I've been unable to find an answer in the manual.
    I have a Raymarine direct drive autopilot. Is there a way of setting it up so that it can lock the rudder in a fixed position? I've been lashing the wheel to achieve the same thing but it's a bit of a pain, and you are left with a little play in the system, which on a bumpy night translates into noise as the autopilot ram slides in and out. Seeing as it's right underneath our berth it's not ideal!
    Moody 39- Deb 33- Wayfarer- Wanderer
  2. #2
    Join Date
    Nov 2009
    Southampton
    Posts
    35,321
    Default Re: Can you use your autopilot to lock the rudder?
    Iím not aware of a way to tell the system to do that.
    If youíre determined to try it, you could add a switch that applies 12v to just the clutch input, which will connect the ram to the gearbox; I donít know how easily the gearbox backdrives, if at all. Might be best to wire the switch so that it disconnects the clutch from the pilot as well as connecting power, just in case the pilot doesnít like having 12v fed back up its output.
  3. #3
    Join Date
    Mar 2010
    Ammersee, Bavaria
    Posts
    4,651
    Stupid question perhaps ... but do you not have a clutch in the centre of the wheel? Rotate clockwise to lock the wheel off? ... perhaps it's an AWB thing?
    The best argument against democracy is a five-minute conversation with the average voter.
  4. #4
    Join Date
    May 2005
    Posts
    4,845
    No clutch at the wheel, I'm afraid.
    It's a rod steering system and even with the wheel tightly lashed, which itself is pretty hard to do, there is just enough play left in the system to allow some movement and noise in the AP ram.
    There is a bit in the manual about 'jog steering' which sounds promising, but I could be misunderstanding it.
  5. #5
    Join Date
    Sep 2010
    Where life is good
    Posts
    13,245
    What PRV said.
    I got that from Raymarine themselves. Reason being I had an FP Pajot (of the osmosis fame) where the outdrive was behind the rudder! When manourvering and applying lots of reverse to pivot, the wheel used to kick something rotten.
    Life is too short to drink bad wine.
  6. #6
    Join Date
    Mar 2007
    Over here
    Posts
    616
    Have you tried lashing the wheel to hard over / full extent of the ram? That my have less play than straight ahead
  7. #7
    Join Date
    Mar 2004
    Posts
    5,929
    'there is just enough play left in the system to allow some movement and noise in the AP ram'
    where exactly is the play, can you rig something up to lock the rudder arm that is fixed to the post ?
  8. #8
    Join Date
    Feb 2005
    Guernsey
    Posts
    3,390
    Have you tried turning the auto pilot off?
    On the internet no one knows you are a donkey.
  9. #9
    Join Date
    Nov 2009
    Southampton
    Posts
    35,321
    Quote Originally Posted by guernseyman View Post
    You don't see the problem in a system that locks the rudder when the autopilot is turned off?
  10. #10
    Join Date
    Nov 2009
    Southampton
    Posts
    35,321
    Quote Originally Posted by Tomahawk View Post
    What PRV said.
    That's interesting - I did wonder whether it was ok mechanically to have the rudder clutched in and pushing against a non-running gearbox and motor. I thought it probably was, but you're confirming that Raymarine agree?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
