Results 1 to 5 of 5
  1. #1
    Join Date
    May 2003
    Exmoor. Boat in Dartmuff.
    Posts
    2,715
    Default Mixing solar panels.
    I have two panels wired in series one of which has failed. I notice that output has increased for much the same dimensions. Any problems mixing panels of different capacities?
    Remote boat monitoring/control For peace of mind
    http://www.skippersmate.co.uk
  2. #2
    Join Date
    May 2005
    up on the moors.
    Posts
    33,141
    Default Re: Mixing solar panels.
    What sort of regulator/controller are you using ?
    I suspect that output V from both the new and the old will be IRO 18 - 20V DC. Have you tested the two panels' open circuit V ?
    A good controller will cope with two inputs differing by ~=2V.
    I think, therefore I am. I am, therefore I sail.
  3. #3
    Join Date
    Mar 2010
    Ammersee, Bavaria
    Posts
    4,647
    Quote Originally Posted by pessimist View Post
    Yes, you can, but the specifics of your panels, the charge controller and the wiring are important if you want to use the extra capacity of newer panels.
    https://solarpanelsvenue.com/mixing-solar-panels/
    The best argument against democracy is a five-minute conversation with the average voter.
  4. #4
    Join Date
    May 2003
    Posts
    2,715
    Quote Originally Posted by sarabande View Post
    K
    It's a 30amp mppt controller with the panels wired in series so only one input. Can't tell you what the ocv is cos one is broke innit😀
  5. #5
    Join Date
    May 2003
    Posts
    2,715
    Quote Originally Posted by Baggywrinkle View Post
    Thanks, most enlightening.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
