Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Join Date
    Apr 2019
    Cornwall - top end :-)
    Posts
    79
    Default Frame for solar panels
    Morning all, from a lovely sunny Cornwall!
    I'm after a frame being made for my solar panels (to be purchased). Meself, and the other half, aren't really frame makers and we don't want it to look overly botched
    Can anyone recommend either someone who can make them or something that we could adapt (we're not bad at adapting).
    Thanks all
  2. #2
    Join Date
    Feb 2010
    Bristol
    Posts
    2,055
    Default Re: Frame for solar panels
    I approached a food grade stainless steel company which weld and make stuff for industry. Most major cities have them.. They quite enjoyed the project actually but you'll need be specific with your drawing. Also much food grade stainless is brushed and not polished. You'll want to ask for polished to prevent corrosion.
  3. #3
    Join Date
    Feb 2010
    Bristol
    Posts
    2,055
    Oh and phoenix316.co.uk will do all that in Plymouth.
    www.Chasing-Contours.com - A circumnavigation by boat, bikes, climbing & paragliding
  4. #4
    Join Date
    May 2005
    up on the moors.
    Posts
    33,141
    I'd consider having the frame in aluminium to save weight. Ali does not need polishing and is easier to drill to fix to a gantry or part of the boat if you are fixing direct.
    You could buy alloy angle and then use a structural (metal) adhesive.
    https://youtu.be/5G6Y_SPTfpE
    There are adhesive tapes which do the same job.
    I think, therefore I am. I am, therefore I sail.
  5. #5
    Join Date
    Apr 2019
    Posts
    79
    Quote Originally Posted by northcave View Post
    Thank you
  6. #6
    Join Date
    Apr 2019
    Posts
    79
    Quote Originally Posted by sarabande View Post
    I feel a project coming on Thank you.
  7. #7
    Join Date
    Aug 2004
    Posts
    4,545
    I made my own using aluminium. They have worked well over the last 10 years ( UK and the Med) I used L section angle and just bolted it together. They hinge on the top pulpit rail and so hinge in one direction only using aluminium stays to adjust.
  8. #8
    Join Date
    Apr 2019
    Posts
    79
    Quote Originally Posted by pcatterall View Post
    Right o'.....that's our bank holiday weekend sorted
  9. #9
    Join Date
    Feb 2010
    Bristol
    Posts
    2,055
    I'm unsure of how aluminium fairs long term being vibrated? Stainless tends to flex a little and bend. When is very windy out 360w of panels hanging off the back of our goal posts can vibrate a little. I do wonder if aluminium would fair as well?
  10. #10
    Join Date
    May 2005
    up on the moors.
    Posts
    33,141
    Just found some useful videos for small frames.
    https://www.youtube.com/results?sear...ar+panel+frame
    NorthC, I think Alskade is looking at a medium sized PV panel, not a monster one !
    Also
    https://www.youtube.com/results?sear...nel+frame+boat
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
