Page 1 of 7 123456 ... LastLast
Results 1 to 10 of 64
  1. #1
    Join Date
    Jul 2013
    Posts
    59
    Default Anchor chain length for med
    I have searched through the posts but cannot find a simple answer to this one and would appreciate your collective advice.
    We are heading to the Med next month and I am now questioning the length of anchor chain we will need. Unfortunately our windlass only takes chain so I can't add warp and we have 40m of 8mm chain and a 15kg ROCNA on a Southerly 105 (about 36ft). I would happily add more chain to my existing amount but am not sure a joining link is a safe option so it would mean having to buy a whole new anchor chain.
    I would appreciate any help.
  2. #2
    Join Date
    Nov 2011
    Sydney, Australia.
    Posts
    5,101
    Default Re: Anchor chain length for med
    If you go to Vyv Cox's website he has a section on 'C' links - of which he approves - if you buy the right quality.
    Look at (website), or ring, Tecni in the UK. I believe they sell the 'C' links and will sell mail order. You need to buy one made by Crosby (there maybe other reputable suppliers - but I don't know them and you will not find a reliable 'C' link in your local chandlery!!!)
    I source my Crosby stuff, shackles, through Tecni - they send, cheaply, to Oz.
    Just watch the 'C' link for corrosion every month or so.
    All you need to know now is the extra length of chain you need - sorry I'm not much use there - its a bit far.
    Jonathan
  3. #3
    Join Date
    Jun 2017
    Posts
    170
    It rather depends where in the Med. Some areas such as Turkey shelve dramatically close to shore so you need a large scope of chain. Other areas not so much ie nearby Greek isles. Therefore Turkey could easily be 20m and Greece 5m. Chain x 5 max depth.
  4. #4
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    21,704
    I carry 64 metres but have not been to Turkey. We have had all of it out a few times, Sardinia free anchoring and stern-to anchoring in Greece.
    C-links by Crosby are good but their galvanising is not great, so paint it and inspect occasionally.
    Answers to some technical queries at new website http://coxeng.co.uk
  5. #5
    Join Date
    Nov 2011
    Sydney, Australia.
    Posts
    5,101
    Vyv probably mentions it on his website - he is pretty inclusive.
    But do not try to be clever and weld it - you will destroy, or markedly reduce, its strength and might finish up, much, weaker than your chain.
    In partial defense of Crosby - they do not focus on the marine industry where items are constantly submerged in the sea, smothered in mud and then stored in a warm damp locker - the gal is probably good enough for their primary markets. The method of joining 'C' links, belting them with a big hammer to rivet them together, can do little for the galvanised coating - I'm amazed they last so well.
    Jonathan
  6. #6
    Join Date
    Mar 2010
    Ammersee, Bavaria
    Posts
    4,677
    I used to have 50m but when I replaced the chain I went up to 65m as there have been a few occasions when I wanted a bit more out. Cruising ground - Croatia.
  7. #7
    Join Date
    Mar 2002
    Greenwich
    Posts
    7,249
    We moved up from 35m of chain to 60m of chain plus 60m of warp (mostly Croatia and Greece) and used all 60m in our first trip with the new chain in a popular bay where you anchor in 18-20m of water. Since then we have run out of chain a few times in our first Greek season but only by dropping anchor too far from the quay - never in free anchoring. Eventually we will change our 10mm chain to probably 100m of 8mm but for now the combination seems fine although rarely used and a bit hassly when we have.
  8. #8
    Join Date
    Dec 2007
    UK, Greece and Spain
    Posts
    23,219
    I used to have 50m of chain and did struggle on a couple of occasions. Now have 70m and not had a problem.
  9. #9
    Join Date
    Jul 2013
    Posts
    59
    Thanks all, much appreciated. We plan on staying in the Med so may well visit Turkey sometime in the future. I will certainly look at the C link and now check out actually how much chain will fit in my locker. It sounds as if 100m would be the best choice.
  10. #10
    Join Date
    Nov 2011
    Sydney, Australia.
    Posts
    5,101
    For your information:
    100m of 6mm chain weigh 80kg
    8mm chain weigh 145kg
    10mm chain weigh 230kg
    12mm chain weigh 380kg
    Approximately
    and smaller chain, obviously, takes up less room
    Its a lot of weight in the bow if you have a modern relatively light yacht. Which is why, I suspect, RupertW, above, Geem (I think) and ourselves moved to smaller chain, of higher strength. Note there is an additional cost of downsizing - you will need a new gypsy. We went from 50m of 8mm to 75m of 6mm.
    Jonathan
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
