Page 3 of 12 FirstFirst 12345678 ... LastLast
Results 21 to 30 of 115
Thread: Chum
  1. #21
    Join Date
    Nov 2011
    Sydney, Australia.
    Posts
    5,480
    Default Re: Chum
    Quote Originally Posted by noelex View Post
    Lead is the best material. As it is much denser a kilo of lead will have more effect than most other materials. The smaller size per kilo also makes handling easier.
    I would hate to be thought of as being controversial and I am honestly fascinated.
    What is the science behind a kilo of lead being better than a kilo of say,. cast iron or even a kilo of aluminium.?
    Jonathan
  2. #22
    Join Date
    Apr 2005
    Shoreham - up the river without a paddle.
    Posts
    1,225
    Default Re: Chum
    I can think of two good reasons for lead being better then iron:
    - It doesn't go rusty, leaving dirty marks everywhere and being unpleasant to handle.
    - Being softer, albeit denser, when dropped on deck it is marginally less likely to make a dent.
    But aluminium trumps it on both these counts if the corners are well radiused.
    However, use zinc and you could also claim that it was protecting the chain! :0)
  3. #23
    Join Date
    Sep 2010
    West Sussex / Hants
    Posts
    28,771
    Default Re: Chum
    For a start,
    a kilo of Aluminium will be huge compared to lead; and alloy corrodes, lead doesn't.
    Apart from those major differences they're the same
    Anderson 22 Owners Association - For info please ask here or PM me.
  4. #24
    Join Date
    Oct 2004
    I know how fast I'm going, but not where I am
    Posts
    6,954
    Default Re: Chum
    Quote Originally Posted by Neeves View Post
    Jonathan
    A kilo of lead has a density of 11.3 kg/l, so a volume of 0.088 l. That volume displaces 0.088 kg of water, so the effective mass of the lead in water is 0.912 kg. For aluminium with density 2.7 kg/l the effective mass of a kg in water is 0.63 kg.
  5. #25
    Join Date
    Oct 2004
    Posts
    6,954
    Default Re: Chum
    Quote Originally Posted by Seajet View Post
    ...alloy corrodes, lead doesn't.
    Let me update you on the advances in aluminium metallurgy since about 1950...
    "...some aluminium alloys corrode in seawater, while others do not..."
  6. #26
    Join Date
    Sep 2010
    West Sussex / Hants
    Posts
    28,771
    Default Re: Chum
    Brilliant sounding right on PC and wrong as always, thanks for a much needed laugh Angus
  7. #27
    Join Date
    Oct 2004
    Posts
    6,954
    Default Re: Chum
    No idea what you are on about. Are you still confused about relative densities and different weights of different density materials when displacing a fluid? Here's a quick link that might help relieve your befuddled state...
    https://en.wikipedia.org/wiki/Archimedes%27_principle
    Andersen 22. The best winch never made.
    miniwinwm.wixsite.com/miniwinwm
  8. #28
    Join Date
    Sep 2001
    Home - Sothampton, Boat - Gosport
    Posts
    10,316
    Default Re: Chum
    Quote Originally Posted by AngusMcDoon View Post
    That's the bit that matters.
    Personally, I've never used a chum, I prefer to have the extra weight in my anchor. I've just swapped my 17m of 8mm chain for the same length of 6mm, which weighs around 2/3 as much - important on a small boat without a windlass, especially following an illness that has sapped my strength, and I carry an extra length of chain that I can add in when needed.
    The chain is possibly a little undersized for a solidly built 24 footer, but with a bit of rope out as well, I can't see me ever having to anchor in conditions that will put over a tonne of load on my anchor.
    Steve
    Never believe anything until it has been officially denied.
  9. #29
    Join Date
    Oct 2004
    Posts
    6,954
    Default Re: Chum
    Quote Originally Posted by Stemar View Post
    I'm not an anchor expert, but I suspect that if you want to carry extra metal around, the best place to put it for ultimate holding when the weather gets gnarly is in a larger anchor.
  10. #30
    Join Date
    Sep 2010
    West Sussex / Hants
    Posts
    28,771
    Default Re: Chum
    Which clearly shows Angus, now let us men get on with proper advice
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
