Results 1 to 8 of 8
  1. #1
    Join Date
    Mar 2019
    Posts
    4
    Default Tidal Thames Moorings
    Hi All
    I am taking a trip to St Kats in August and will pass Richmond about 7am high tide being about 5am but cant get into st Kats untill 14.40 , we plan a little venture out past the Barrier but will still have a few hours to kill , last time we did it we lost and engine under tower bridge and had to hover around tower bridge on one , not fun. Any ideas for a spot to moor up for a couple of hours downstream of Richmond preferable with breakfast or lunch but doesn't have to?
    We we were thinking Chelsea Harbour pier?
  2. #2
    Join Date
    Apr 2011
    Posts
    251
    Default Re: Tidal Thames Moorings
    Chiswick Pier?
  3. #3
    Join Date
    Jun 2001
    Oxfordshire
    Posts
    4,194
    There are very limited options, Imperial Wharf( Chelsea Pier) is good but it seems to be filling up with long term moorings so you will need to ring and check. Further up Chiswick pier is good for a few hours but again might be full.
    You can moor on the back of Tower pier at St Kats but its not very comfortable, or there is the St Kats waiting Bouys.
    Hemitage moorings a bit further down but I'm not sure if they do short stay.
    Thats it I think.
  4. #4
    Join Date
    Jul 2007
    Posts
    8,305
    Did you have a broken throttle cable on your previous trip?
  5. #5
    Join Date
    Aug 2015
    Thames & Kennet Marina
    Posts
    133
    If a weekend you should be able to stop at Chelsea Harbour Pier - give them a call; we've overnighted there in the past but you can probably stop there for a few hours.
    (During the week the Thames Clippers stop there)
    Otherwise Chiswick Pier allows you to stop for a few hours - not done it myself but it's certainly mentioned on their website.
  6. #6
    Join Date
    Jul 2001
    Weybridge, UK
    Posts
    732
    If you are going past the Thames Barrier you could anchor at Horseshoe Corner.
  7. #7
    Join Date
    Nov 2001
    Medway
    Posts
    19,653
    Hermitage moorings.A WARNING
    Fine if you are a 150 ton 30 metre ex ballast barge but no place to be if you are a small leisure boat.
    Booked in there a few years ago. Managed to stay there for an hour or so before prospect of serious damage to boat by wash from passing craft forced our departure.
    We were tucked inside which you thought would have provided some protection
    Fortunately, St Kats took pity on us, squeezed us in next to the Gloriana on last lock in.
  8. #8
    Join Date
    May 2008
    Limehouse hole
    Posts
    474
    I was going to suggest Greenwich Yacht Club then thought better of it. Might not work for the timing to get into St Katherine's haven.
    It was a bit unclear whether op was going down to the barrier first and back up. If that were the case there would be no need to wait as you could just run down river and turn back as and when.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
