Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Gas regulator
  1. #1
    Join Date
    Apr 2019
    Posts
    21
    Default Gas regulator
    Hello,
    We’ve got a new (30 year old) hallberg rassy and although we’ve have our gas hoses changed and certificate, we’ve just gone to change the bottle of empty gas and the regulator appears to be stuck. It does look pretty corroded. Does anyone know a good, safe, way to get this off?
    Thank you,
    Lauren
  2. #2
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    43,334
    Default Re: Gas regulator
    Quote Originally Posted by lrlloyd View Post
    Hello,
    Thank you,
    Lauren
    You don't say what type of gas cylinder or gas type. Calor butane, Calor propane, Camping Gaz or some other
    If you are trying to remove the regulator from a small Calor butane or a Calor propane cylinder, or a regulator from a Camping Gaz to Calor adapter valve are you aware that the thread is left handed?
    Assuming you have a fitting which requires a spanner have you tried a gentle tap or two with a decent sized hammer?
    Have you tried heating the offending joint with some very hot / boiling water ? No, I suppose because you cannot heat the water ! A hair dryer ??
  3. #3
    Join Date
    May 2016
    Suffolk
    Posts
    7,646
    Curious that a gas engineer would change the hoses and leave a rusty, stuck, regulator ?
    Rainbow Marine.
    www.rainbowmarine.co.uk
  4. #4
    Join Date
    Jan 2017
    Posts
    2
    Paul raises a good point. If you're still in the vicinity of the gas engineers I'd be inclined to raise the issue them...why didnt they change the regulator.
    If not, I'd give it a sharp tap with a hammer, worst case is you'll damage the regulator and/or thread but since it needs a new reg anyway and you'll be exchanging the bottle.
    Otherwise, take the pipe off and exchange bottle with the reg still attached
  5. #5
    Join Date
    Sep 2001
    Me - Zumerzet Boat - Wareham
    Posts
    12,064
    A picture of the offending assembly would help.
    I've just replaced my regulator. The options and combinations are multitudinous.
    MontyMariner.co.uk
    Facilitated by AWESEM WP Agency
  6. #6
    Join Date
    Jun 2018
    In the Euro zone, not Poundland.
    Posts
    3,405
    In way shape or form a gas engineer, but would a little Plusgas over night work to free it up work?
  7. #7
    Join Date
    Feb 2003
    Posts
    401
    its a left hand thread usually .. are you turning the correct way??
  8. #8
    Join Date
    Jul 2002
    Posts
    43,334
    Quote Originally Posted by owen View Post
    As already suggested in #2
  9. #9
    Join Date
    Jun 2014
    Posts
    80
    Hello,
    Thank you,
    Lauren
    can i suggest you get a gas engineer as your original engineer should have checked regulator and changed if corroded especially if he has issued you with a gas certificate as it`s pretty crucial if corroded you are not using regulator as it block`s up and its possibly not marine grade as well but with no pic`s its hard to verify and it`s strange someone would change hose`s and not test and check regulator when i do check`s any corrosion and ill fail it not worth my job leaving it
    pics be good tho
    nick
    also no hammer on joints please as if you not sure what your doing your could end up with a big bang and breaking off bottle connection
  10. #10
    Join Date
    Oct 2004
    I know how fast I'm going, but not where I am
    Posts
    6,929
    Regulators aren't expensive & need to be replaced periodically to keep a gas system safe. Buy a new one.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
