Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    Join Date
    Sep 2016
    London / Suffolk
    Posts
    759
    Default Removing Wax from a Topper Dinghy
    Ok, so for all of you who followed the previous thread here's an update.
    Before buying the Topper I had looked at various videos about tarting them up, and seen how easy it was to do with White Spirit, wire wool and a hot air gun.
    So of course being a numpty I viewed the one I bought through rose tinted spectacles, and didn't spot the layers and layers of what appears to be wax covering the deck. White spirit seems to dissolve it making a thickish goo, which I then need to wipe off, let dry and repeat. I've even taken to scraping as much off as I can with a paint scraper.
    This is turning into a very very long process, and is not going to be easy on certain areas, so I was wondering if any of the clever people her had a better idea on how to remove the wax?
    I probably shouldn't bother, but I'd like the boat to be fairly clean and on the places I've managed to get back to the original deck the yellow is like new.
    Someone more informed will come along any minute
  2. #2
    Join Date
    Jun 2008
    Surrey and Gosport UK
    Posts
    1,528
    Default Re: Removing Wax from a Topper Dinghy
    Have you thought about buying some deck cleaner?
  3. #3
    Join Date
    Sep 2016
    London / Suffolk
    Posts
    759
    Quote Originally Posted by ashtead View Post
    I've tried Owatrol marine strip, oxalic acid, and no luck unfortunately!
  4. #4
    Join Date
    May 2007
    Cambridge, UK
    Posts
    6,000
    Wax should melt in hot water. Would a wallpaper stripper work, coupled with some absorbent paper? Or even a hot air gun, again followed by something absorbent? If you get wax on clothing, ironing it through blotting paper works very well.
  5. #5
    Join Date
    Sep 2016
    London / Suffolk
    Posts
    759
    Quote Originally Posted by AntarcticPilot View Post
    I thought about trying an Iron with newspaper, I'll give that a go later
  6. #6
    Join Date
    May 2007
    Cambridge, UK
    Posts
    6,000
    Quote Originally Posted by dolabriform View Post
    I'd be cautious about using an iron - you might get the setting too high and melt the polypropylene of which it's made.
  7. #7
    Join Date
    Jun 2008
    Posts
    1,528
    I just wonder if this is really wax but there are products that take wax candles out of limestone type surfaces that work quite well so you might look at products that remove wax from stone fireplaces
  8. #8
    Join Date
    Sep 2016
    London / Suffolk
    Posts
    759
    ok, the Iron didn't work.
    The hot air gun helps to remove some of the thicker areas, but in the main I'm left with this which I can't seem to remove.
  9. #9
    Join Date
    Feb 2007
    Essex
    Posts
    22,018
    Enter it for the Turner prize. You could perhaps try acetone, if the plastic will take it.
    I'm still trying to get my head round the thought of a polypropylene iron.
    Far away is near at hand in images of elsewhere
  10. #10
    Join Date
    Jan 2011
    No fixed abode
    Posts
    2,633
    Steam cleaner?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
