Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: LED Nav lights
  1. #1
    Join Date
    Jun 2019
    Posts
    2
    Default LED Nav lights
    I need to replace my masthead Tricolour/all round white light and am considering an LED type. I'm aware that the circuitry used to drive the LEDs can cause RF emissions which can interfere with VHF and AIS. Previous threads have discussed how to test for this and to find out if your light has this problem.
    Is there any information out there as to which brands do not have this problem? It would be a pity to spend a lot of money on a new light, only to find that it degraded VHF performance.
    Any information/advice will be greatly appreciated.
  2. #2
    Join Date
    Aug 2011
    On the Celtic Fringe
    Posts
    13,974
    Default Re: LED Nav lights
    Hello and Welcome to the forum
    Many people use Boatlamps https://boatlamps.co.uk/
    Cynical Scottish almost retired engineer.
  3. #3
    Join Date
    Aug 2001
    hampshire
    Posts
    248
    Strong recommendation for Boatlamps as above.
  4. #4
    Join Date
    Mar 2010
    Ammersee, Bavaria
    Posts
    4,677
    Converted all my lights to LED last year, boatlamps is the place to go.
  5. #5
    Join Date
    Jul 2001
    Cyberspace
    Posts
    34,892
    NASA have categorically assured me that their led masthead tricolour does not cause any RF interference. It is also a cheap (approx. £60), thoroughly waterproof unit that no-one seems to have anything bad to say about.
    - W
  6. #6
    Join Date
    Jan 2006
    Bristol
    Posts
    692
    Quote Originally Posted by webcraft View Post
    - W
    ... including me. I had this LED tricolour mounted next door to my masthead aerial which serviced both VHF and AIS. No problems whatsoever.
  7. #7
    Join Date
    Jul 2018
    Bewdley, Worcs
    Posts
    375
    Quote Originally Posted by Sandy View Post
    The only issue I have with the tricolour from Boatlamps is that on mine, the lamp appears to have been soldered into it's base around 10 degrees off axis, so the red/green divider of the lamp does not match up with the red/green divider of the housing .. giving a rather "confused" region dead ahead.
  8. #8
    Join Date
    Dec 2014
    N of Ardnamurchan, winter Loch Melfort
    Posts
    884
    - W
    +1 for the NASA unit. Fitted one a couple of years ago and very pleased.
  9. #9
    Join Date
    Jun 2008
    Surrey and Gosport UK
    Posts
    1,528
    As a word of warning ours stopped working recently and reason seems to be its full of water so if the OP is considering a new light or replacing bulbs with LED then checking out the water resistance of any unit might be worth looking into.
    I think these units are quite pricy so who builds ones that act as a raincatcher?
  10. #10
    Join Date
    Jul 2001
    Cyberspace
    Posts
    34,892
    Quote Originally Posted by ashtead View Post
    Which make/model?
    - W
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
