Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 55
Thread: KAD44 issue
  1. #1
    Join Date
    May 2001
    ation, Loc: ation, Loc: ation.
    Posts
    15,923
    Default KAD44 issue
    Gggrrrr, boat has developed an odd problem. When starting the port engine from cold and on tickover I get intermittent short screeching noises with momentary increases in revs. Restart and boat runs and performs fine. Have not managed to replicate issue with engineer present but will try again from a cold star tomorrow.
    Any ideas?
  2. #2
    Join Date
    Jun 2006
    Posts
    1,233
    Default Re: KAD44 issue
    Belt slipping?
    Supercharger clutch slipping?
  3. #3
    Join Date
    May 2001
    Posts
    15,923
    Quote Originally Posted by julians View Post
    Belt slipping?
    Belts all look good so we don't think it's that.
  4. #4
    Join Date
    Jun 2006
    Posts
    1,233
    Belts can look good and still screech, try spraying a bit of silicone lubricant on the belts and see if the noise immediately stops. If it does stop it will only stop for a minute or so, but it will rule in/out belts.
  5. #5
    Join Date
    Jun 2006
    Posts
    1,233
    Ps if it is the belts screeching, then the next step is to work out why they are slipping, has a pulley siezed? Is the alternator seizing up etc etc, water pump, power steering pump etc etc.
  6. #6
    Join Date
    Feb 2015
    Conwy
    Posts
    3,881
    Quote Originally Posted by petem View Post
    The crank to water pump belt is usually the culprit. Especially if the boat has stood a short while and developed a bit of flash rust on the crank pulley wheel. Soon clears and then isn't replicated.
  7. #7
    Join Date
    Oct 2006
    Éire
    Posts
    3,526
    Replace the belts. Most likely the main circulation belt.
    Use genuine belts, whoever makes them does a good job. Do not use Gates unless you want screeching after 10 hours... Don't ask how I know
  8. #8
    Join Date
    Feb 2015
    Conwy
    Posts
    3,881
    BTW sounds awful. Much worse than the un-silenced SC of a 42 on kickdown. Make you sit up and take notice for sure.
  9. #9
    Join Date
    May 2001
    Posts
    15,923
    How would a belts issue give a rise in RPM? Also, after a restart boat works perfectly. Belts are genuine VP.
  10. #10
    Join Date
    Oct 2008
    New Forest
    Posts
    1,844
    I could be wrong but i have a feeling that rev counters get their info from alternators .
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
