Page 8 of 8 FirstFirst ... 345678
Results 71 to 72 of 72
Thread: KAD44 issue
  1. #71
    Join Date
    Oct 2003
    west yorkshire
    Posts
    4,064
    Default Re: KAD44 issue
    pic as promised
    if you follow the cable that comes out of the fuel injection pump, it will go to a big round multi pin connector. On the pic shown my connector is covered in green paint and I have pulled it out a bit for clarity. Yours may well be lurking under the black fuse/relay box assembly. It may appear stuck (one of mine was) but its probably just green paint - however go carefully, don't yank it.
    probably worth releasing the ECU main connector too (press the red latch at the bottom of the connector down to unlock it)
    give them all a sprat and reconnect a few times. Make sure batteries are all off first.
  2. #72
    Join Date
    May 2001
    ation, Loc: ation, Loc: ation.
    Posts
    16,514
    An update. I asked my guy to thoroughly check and clean ALL the engine wiring, connectors, contacts, plugs, etc. Most looked pretty good however there was minor signs of corrosion on one or two connectors. Probably took him an hour to do.
    Prior to this work, we had three successive starts where the issue manifested itself. Following the checking / cleaning I have had four successive starts with no issue.
    So with any luck this problem has gone away .
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
