Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Engine problem
  1. #1
    Join Date
    Aug 2001
    Clyde
    Posts
    904
    Default Engine problem
    Currently stuck on a mooring in Brodick Bay with non-functioning engine (Volvo Penta D1-20F with saildrive). No drive, bad juddering on acceleration in gear, doesn’t make its usual muscular sound when revved in neutral. The last would suggest its not something round the folding prop. Suggestions welcomed.
  2. #2
    Join Date
    Jan 2003
    Clyde
    Posts
    7,297
    Default Re: Engine problem
    Quote Originally Posted by mick View Post
    sail home then get a tow or use the dinghy with an outboard if you have one. Where are you based?
  3. #3
    Join Date
    Aug 2001
    Clyde
    Posts
    904
    Quote Originally Posted by Spyro View Post
    Aye, that’s the plan. Was hoping someone might suggest what’s causing the problem. Based Port Bannatyne.
  4. #4
    Join Date
    May 2016
    Suffolk
    Posts
    7,645
    Your description is rather vague. So, out of gear the engine does what ?
    Shot in the dark..... does it run rough and "lumpy", won't rev properly ? If so, have you checked the fuel filter ? If you have a spare, try it.
    Rainbow Marine.
    www.rainbowmarine.co.uk
  5. #5
    Join Date
    Jan 2003
    Clyde
    Posts
    7,297
    If it won't run properly in Neutral the most likely cause is fuel or lack of it due to Air in the system or as Paul suggested Dirty filters. Has any work been done recently? Have you tried bleeding the fuel system? Other than that it's likely to be more serious.
  6. #6
    Join Date
    Aug 2001
    Clyde
    Posts
    904
    Quote Originally Posted by PaulRainbow View Post
    Under acceleration the engine judders violently. That would suggest possibly the prop being fouled. However, accelerating in neutral does not produce the usual sound - the note is much weaker, less powerful although it does accelerate. So, not the prop? I changed both primary and fine filters 12 engine hours ago and the engine has been its normal reliable self, until now.
  7. #7
    Join Date
    May 2016
    Suffolk
    Posts
    7,645
    From what you say, no, not the prop. Still worth checking the filters, may have stirred some crap up during your trip out ?
    Rainbow Marine.
  8. #8
    Join Date
    Aug 2001
    Clyde
    Posts
    904
    Thanks for contributions. I’ll update you when sorted.
  9. #9
    Join Date
    Jun 2015
    Posts
    1,497
    If I follow you correctly you changed the filters before this problem started? Check the seals for air leaks.
  10. #10
    Join Date
    Sep 2001
    Me - Zumerzet Boat - Wareham
    Posts
    12,054
    I would work from the prop back, so it's got to be getting cold and wet, just to satisfy yourself that all is in order.
    I know nothing about saildrives, but can you put a hand to it whilst running in neutral and in gear to feel for vibration?
    Are the symptoms the same whilst running in neutral and in gear forward and reverse?
    MontyMariner.co.uk
    Facilitated by AWESEM WP Agency
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
