Results 1 to 6 of 6
  1. #1
    Join Date
    Mar 2011
    Essex
    Posts
    214
    Default Water Tank Float Sensor
    I am trying to find one online but having little luck
    I have a plastic fresh water tank and the sensor, which is screw in, has had the thread corroded away, hence leaking. Its 250mm long, not sure of the thread size, but hoping they are a standard fitting. Cant find anything online.
    Does anyone have an ideas where to look for a replacement?
    Thank you
  2. #2
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    21,978
    Default Re: Water Tank Float Sensor
    ASAP probably have the biggest range. Not sure what type you have but the Osculati ones do most fluids but not a screw in type. You need to match the resistance with the instrument head.
    Answers to some technical queries at new website http://coxeng.co.uk
  3. #3
    Join Date
    Apr 2006
    Portsmouth, UK
    Posts
    2,956
    If you're in Portsmouth you can pick one up here..or mail order.
    https://www.furneauxriddall.com/acat...E_S3_E250.html
    1 1/4 BSP is actually about 42mm across the male thread. The one I've linked to is the European as opposed to the US resistance which is the other way round and about 230 ohm down to zero.
    They sell on eBay as AutoMarineElectrical.
  4. #4
    Join Date
    Apr 2006
    Portsmouth, UK
    Posts
    2,956
    Correction. US resistance is 240 down to 30 ohm whereas European is zero up to 190 ohm.
  5. #5
    Join Date
    Apr 2006
    Portsmouth, UK
    Posts
    2,956
    If on the other hand you did have a hole in the tank with five screw holes around it, there would have been an adapter to allow you to use the threaded senders.
    https://www.furneauxriddall.com/acat....html#SID=1102
  6. #6
    Join Date
    Mar 2011
    Essex
    Posts
    214
    Thank you thats the one.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
