Page 1 of 53 1234561151 ... LastLast
Results 1 to 10 of 529
  1. #1
    Join Date
    Jul 2018
    Bewdley, Worcs
    Posts
    408
    Angry The end of owner maintenance ...
    If you have not seen this consultation already, I suggest you read the documents and respond.
    https://www.gov.uk/government/consul...-safety-at-sea
    Effectively, many of the clauses woudl see the end of owner maintenance on pleasure craft.
    eg:
    Unless specifically trained, experienced and/or qualified to do so, repairs should not be carried out by the owner,managing agent or skipper.
    and ...
    All of this makes a technical inspection of a rig and its rigging a job for an experiencedmarine professional only.
    etc etc ..
  2. #2
    Join Date
    Apr 2005
    Shropshire
    Posts
    8,830
    Default Re: The end of owner maintenance ...
    A lot of repairs are carried out at sea of necessity by the owner. Hard to see how this can change.
  3. #3
    Join Date
    Aug 2018
    Posts
    98
    perhaps the person drafting the regs should read these forums as to the areas of maintenance and how it's carried out. silly sods. trying to regulate a 40year old modified, held to gether with gaffer tape and epoxy 32ft cruising yacht is going to be interesting. Anyway reading this stuff is what the RYA is paid to do luckily
    also misses the point that doing maintenance and repairs is the key way to get to know the boat and increases safety at sea where the knowleageable owner will then have the tools and info to repair said part when it goes ping mid passage. In fact I'd say it was a hugely important aspect of being a competent skipper - unless of course they are going to put haul out facilities mid channel, biscay, atlantic etc
  4. #4
    Join Date
    May 2001
    Posts
    14,356
    Is this consultation a precursor to legislation or is it merely intended as a base for issuing guidelines for what is considered to be "good practice" (or what we would call 'good seamanship')?
    It seems to me to be the latter. I believe that your country does not even have the equivalent of a 'nautical license' for leisure craft (I might be wrong) and so legislation would appear to be highly unlikely.
    Should we paint what is on a face, what is inside it, or what is behind it?
  5. #5
    Join Date
    May 2003
    SPAIN,Galicia
    Posts
    12,553
    Common sense does not count and civil servants just follow orders any laws stopping people working on their boats should be vigorously condemned through the RYA.In Spain you have to pay for a survey every five years,license to print money and further make boating an elitist pastime.
  6. #6
    Join Date
    Oct 2007
    Central Scotland
    Posts
    2,340
    From the intro to the consultation..
    " The main reason for the intervention is to reinforce to owners, managing agents and skippers what is good practice in terms of safety when going out to sea. This is to reduce the risk of any accidents occurring as a result of not following the most acceptable standards of safety required. Another reason for the intervention is to ensure that guidance on safety is applied equally to those who fall within a regulatory framework and to those that fall outside it. This will ensure that as many stakeholders as possible are aware of what practices they need to put in place to meet the acceptable level of safety. The guidance contained within this collection of MGNs is not looking to amend or change the text of the applicable regulations, but rather provide further detail on the intent of the regulation."
    That doesn't sound too ominous.
    Geoff. C.: Galvanizing and anchor manufacturing.
  7. #7
    Join Date
    Aug 2009
    Finchampstead, Wokingham, Berks
    Posts
    1,991
    Should is not "must"
  8. #8
    Join Date
    Oct 2018
    A Member State of the European Union
    Posts
    5,482
    It would be sad if we were not allowed to carry out repairs and modifications to our boats because I get a lot of pleasure from it as well as saving myself a great deal of money. However, I am always amazed at how tolerant some boatyards are of amateurs carrying out work that could not only endanger themselves but others. Dry grinding off antifoul is one example, with the toxic dust flying everywhere
    "Brexit: like watching a library being burned down by people who can't read"
  9. #9
    Join Date
    May 2001
    Posts
    8,835
    Not deleted by Old harry, but never mind....
    It's not entirely clear to what extent these new guidelines apply to leisure boats - will it extend to my little sailing dinghy for example?
    The papers refer to a 'Good practice' code for leisure boats, which means the whole thing is advisory. But advisory codes have a bad habit of becoming incorporated in legislation. In any case, try justifying not having followed the guidelines to your insurers after an incident!
    Also, HMs could easily incorporate guidelines in to local harbour rules. 'All boats using the harbour must be maintained in line with MCZ Guidelines'
    But yes, owner maintenance is fundamental to sea safety: If you maintain your own boat and something goes wrong then you have a better chance of getting yourself out of trouble, or even identifying it before it develops in to a serious problem.
    But of course there are a lot of novices operating/owning boats of all states of repair and seaworthiness: I shudder nowadays at some of the risks I took 60 years ago with my first boats. A member of my YC was recently complaining about the state of a boat he had bought. One of the worst issues was that the sheet winches had been glued in place! I remember walking away from viewing a boat when the owner proudly showed me the 'bathroom wallpaper' he had used to make it look good!
    But there does seem to me too much of an emphasis on the use of professionals to check and repair boats in the guidelines as they stand. We all know the high standards a knowledgeable skilled amateur can acheive. Equally mos of us who have been around for many years know the appalling botches that can be made in the name of 'maintenance'!
    Is Conservation for wildlife or conservationists?
    http://boatownersresponse.org.uk
  10. #10
    Join Date
    Jul 2018
    Bewdley, Worcs
    Posts
    408
    Whilst you are correct that these are not mandatory, if something was to happen, effectively they are, because if somethign goes wrong, you end up standing in front of a Jury, facing their lawyer armed with these notes, explaining that because you had done all your own maintenance over the winter that "the owner failed to comply with accepted best practice"
    Say your engine breaks down coming in on a rough night, your boat is lost on rocks and your insurance company declines to pay because you have not followed accepted good practice and have done all the maintenance yourself for the last 30 years, instead of using a Marine Professional.
    Or the rig comes down in a storm, even though inspected yearly and 7 years old, the instructions from the original builder state it shoudl be replaced every 5 years (the rig document here makes replacement in line with the builders instructions mandatory).
    Etc etc etc ... while the general advice on the quality and integrity of repairs is good and sensible, the requirement that only a Marine Professional should carry out any work or inspection is onerous.
    At the very least they should contain the phrase "Marine Professional or other Competent Person" at least then you are able to argue in front of a jury that you were competent to complete the task.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
