Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 59
  1. #1
    Join Date
    Jul 2001
    Cyberspace
    Posts
    35,571
    Default Charging engine battery via 1-2-both switch
    Both solar panel and battery charger are connected to the domestic bank only. Will switching to 'both' charge the engine start battery?
    (No lectures on the satanic nature of 1-2-both switches please, it exists)
    - W
  2. #2
    Join Date
    Dec 2012
    Fortrose
    Posts
    1,535
    Default Re: Charging engine battery via 1-2-both switch
    Yes. Easy to check with a DVM also.
    Folkboat 'Stakkr' - Inverness - http://islandrov.wix.com/island-rov-web
  3. #3
    Join Date
    Oct 2001
    Posts
    1,408
    Yes.
    But I'd be worried about what happens if the domestic bank was knackered.
  4. #4
    Join Date
    Jul 2001
    Cyberspace
    Posts
    35,571
    Quote Originally Posted by James_Calvert View Post
    Yes.
    I don't think it is, but what specifically would you worry about?
    - W
  5. #5
    Join Date
    Mar 2002
    Greenwich
    Posts
    7,446
    If the domestic bank was knackered you could discharge the engine battery. I like 1:2:Both systems for anyone who doesn’t need to ask questions about using them. I always used the B when on board and charging so I could keep an eye but mostly just started with engine only - charged for 15 mins then through Both to Domestic and charged on that.
  6. #6
    Join Date
    Sep 2001
    Home - Sothampton, Boat - Gosport
    Posts
    10,071
    Get yourself one of these
    https://www.sunstore.co.uk/product/e...er-12-24v-10a/
    It'll take care of both batteries while keeping them separate. I also use an el cheapo headlamp relay energised from the alternator charge warning light terminal as a split charge relay. You could do the lot for change from £50
    Yes, I know it isn't the most efficient of controllers, but it does the job unless you're desperate for the last milliamp hour of output.
    Steve
    Never believe anything until it has been officially denied.
  7. #7
    Join Date
    Dec 2012
    Fortrose
    Posts
    1,535
    Quote Originally Posted by RupertW View Post
    Exactly my view.
  8. #8
    Join Date
    Apr 2018
    Mooring, Faro
    Posts
    1,566
    Quote Originally Posted by webcraft View Post
    - W
    Yes it will but, could be a problem if the solar regulator voltage is set too high for the engine battery. Our Trojans charge at 14.82 but the engine (car battery) is sealed so needs lower voltage.
  9. #9
    Join Date
    May 2016
    Suffolk
    Posts
    7,749
    - W
    The single most significant reason 1-2-B switches are not as good as separate switches is the need to fiddle around to get the batteries charged up. Second most significant reason is owners using the switches incorrectly. This idea encompasses both of those points, as do some of the replies.
    All of the time the switch is in "Both" the batteries are in parallel and any issue that affects one battery affects them all. If a battery fails due to a shorted cell, for instance, that battery will get very hot and discharge any battery connected to it. So, if that happens while you have the switch set to both, you lose all power.
    "Not likely to happen" i hear someone saying. But i've seen it happen several times, twice on my own boats (luckily i had separate systems). I received an email from a customer just last week, an extract reads ;
    Whilst under sail alone, a continuous high pitched alarm sounded after about half an hour of turning the engine off. We started the engine and the alarm went off. When we stopped the engine it was then that I noticed the voltage dropping fast on the BVM. The voltage level on the BVM was down to about 10.5v."
    That perfectly describes what happens. If that boat had been using a 1-2-B switch, set to both, the engine battery would also have been flat. Fortunately, the boat has separate switches and split charging.
    So, my advice, don't do it. Fit a VSR, i'd recommend the Victron Cyrix 120a. The advice to fit a headlamp relay is also bad advice, that's not better than using the "both" setting.
    Rainbow Marine.
    www.rainbowmarine.co.uk
  10. #10
    Join Date
    Jul 2001
    Cyberspace
    Posts
    35,571
    I never use the 'Both' switch. I charge the engine battery for 15 minutes after starting the engine then switch to the domestic bank. This is only to top the engine battery up prior to launch or in any other situation where it is inadvertently discharged.
    - W
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
