Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2010
    Posts
    1,435
    Default Rudder bearing for Nauticat 321
    Friend has a leak at rudder stock of a Nauticat 321 (probably just needs packing replaced) but there is also movement of the stock which implies the bearing needs replaced. Nauticat are no more, it seems, so does anyone know suppliers of these bearings before he gets one measured and made.
  2. #2
    Join Date
    Dec 2014
    Eastbourne
    Posts
    81
    Default Re: Rudder bearing for Nauticat 321
    Have he tried the Nauticat Association?
    https://www.nauticatassociation.co.uk/
    You can sign up for free and they often have post on all things Nauticat with knowledgable replies.
  3. #3
    Join Date
    Oct 2004
    Devon
    Posts
    2,220
    Many rudder and shaft bearings are made to order and there are a range of materials that will be suitable.
    Just let the supplier know the Shaft OD , the Carrier ID and Length as well as if it needs a flange.
    Few are stock items as boat builders will sometimes use a selection of stern gear suppliers bought as a package with shafts/bearings/seals/tubes. We supply Maritex rudder bearings and can usually make them up to order in a couple of weeks.
    quicKutter rope cutter, shaft and rudder bearings
    www.h4marine.com
  4. #4
    Join Date
    Oct 2010
    Posts
    1,435
    Thanks for suggestions. He said he was a member of Nauticat association but didn't find it useful. Have passed on Neil_Y's details so he'll probably be in touch when he gets the bearing out.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
