Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. #1
    Join Date
    May 2005
    up on the moors.
    Posts
    33,289
    Default Radar reflector in 'landscape' orientation
    Are there any technical (signal return) reasons why an encapsulated radar reflector cannot be mounted horizontally on top of a gantry about 11ft ASL ?
    I think, therefore I am. I am, therefore I sail.
  2. #2
    Join Date
    May 2001
    Posts
    24,275
    Default Re: Radar reflector in 'landscape' orientation
    Depends on the internal geometry but it is certainly not guaranteed to work correctly. An encapsulated reflector won't be designed to give a return from a signal along the axis like that.
  3. #3
    Join Date
    Mar 2004
    Posts
    10,308
    Quote Originally Posted by sarabande View Post
    https://www.ussailing.org/wp-content...ector-Test.pdf
    Here's a very detailed report. It especially discusses the impact of heel on the effectiveness of the reflectors.
    You never know, I might be right!
  4. #4
    Join Date
    Jun 2005
    Solent, UK
    Posts
    4,610
    It depends on the design. The plastic tubes you see lashed to shrouds a lot don’t work anyway so it will make little difference. A stacked array is designed to work in the vertical plane, so you’ll lose a significant proportion of any return mounting it in an alternative orientation. A lens type, should you be lucky enough to have one, will still work at around 60% effectiveness. A simple corner array, as long as it is mounted in “catchwater” orientation, will work just as well (or poorly, you pays your money.....).
    Grow old disgracefully, it's more fun
  5. #5
    Join Date
    May 2007
    Itinerant. On an adventure!
    Posts
    2,831
    I think they are like horseshoes - they work if you believe in them.
    Never really know, unless you call up some large boat and ask if they can see you.
    Oh, and yes, we have one, but my opinion remains the same.
    Gwylan, a settee with a sail
  6. #6
    Join Date
    Nov 2016
    Posts
    2,453
    If'n you're looking for reliable guidance, then of the many sources of real expertise John Simpson of Echomax is completely reliable. And right. Entirely.
  7. #7
    Join Date
    Jun 2019
    Tynemouth
    Posts
    264
    I am confused why Echomaxes are not considered a standard, essential must-have item, while AIS is the must-have gimmick.
    Can anyone explain?
  8. #8
    Join Date
    Feb 2007
    Essex
    Posts
    22,426
    Quote Originally Posted by Ohlin Karcher View Post
    Can anyone explain?
    I believe that SOLAS thinks otherwise.
    Far away is near at hand in images of elsewhere
  9. #9
    Join Date
    Jun 2019
    Tynemouth
    Posts
    264
    Quote Originally Posted by johnalison View Post
    Otherwise to what, sorry I don't understand.
    ( Anyway, SOLAS are not on board my boat in a murky TSS..)
  10. #10
    Join Date
    Jun 2019
    Tynemouth
    Posts
    264
    Quote Originally Posted by zoidberg View Post
    I have just read your post and now I see you are being sarcastic, have you tried switching on an Echomax when there are some ships steaming at you? They all alter. It's like magic.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
