Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Join Date
    Nov 2016
    Lincoln
    Posts
    829
    Default Re: Small fairlead mounted pulleys/fairleads for 6mm tiller lines
    eBay item 131090123900 , stainless 25mm clamps
  2. #12
    Join Date
    Nov 2011
    Sydney, Australia.
    Posts
    5,264
    Most of the hardware suppliers offer stanchion blocks to keep sidekicks clear. Applications are endless, reefing lines, furling lines (and snubbers attached at the transom - )
    Jonathan
  3. #13
    Join Date
    Nov 2013
    Perth WA
    Posts
    2,061
    Quote Originally Posted by Daverw View Post
    They'd be ideal I think but maybe a bit expensive? I am assuming you'd need 2 in.(50mm) diameter.
  4. #14
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    9,206
    I have mounted my blocks so that I only need one each side & being on cords they self adjust & tension can be adjusted easily
    You may be able to see this in the picture
    The lines have clips to connect to the pullies so they can be disconnected & cleared out of the way when in port
    It is all down to the fact that my wife does not understand me !!
  5. #15
    Join Date
    Jul 2001
    Cyberspace
    Posts
    35,399
    Quote Originally Posted by Daydream believer View Post
    That looks neat. I always assumed a pull nearer to right-angles on the tiller was more effective. Food for thought.
    - W
  6. #16
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    9,206
    Quote Originally Posted by webcraft View Post
    - W
    Yes & No!
    As you rightly say, a pull at right angles would seem to be the most efficient. However, as the tiller moves the angle changes a little, so perhaps the right angle should be measured when the tiller is half over, not straight ahead.
    However, I find that my layout works and it reduces the friction of any extra pulley.
  7. #17
    Join Date
    Sep 2009
    Posts
    554
    Look in the Allen catalogue.
    I use the 'Classic' nylon dinghy blocks,plain bearing, for my wind vane pulleys.
    Easy to attach.
    They move very easily ,never found one to stiffen up,but go for the ball bearing type if you feel flush.
    Doubt you will find any cheaper.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
