Results 1 to 9 of 9
  1. #1
    Join Date
    Sep 2018
    London
    Posts
    86
    Default Mariner 2hp overheating issue
    Hi,
    today my dinghy Mariner 2hp after 2-3 minutes of running started to get lower revs slower and slower (for like 1 minute), and then died. After 5 or 10 minutes I was able to start it again. Metal handle on the back was very hot, so I suppose it has issue with overheating, additionaly, telltale is not pumping any water. Also it has some strange smell, but hard to say exactly what it could be.
    I found 2 guides how to disassamble the engine:
    http://inadee.co.uk/marineroutboard.htm
    https://www.troppo.co.uk/odds/Marine...eplacement.pdf
    Engine looks quite easy to service alone, should I get this replacement kit?
    https://www.ebay.co.uk/itm/Water-pum...cAAOSweUNbHtY0
    Or impeller only would be enough?
    Also, there are 3 small holes, above propeller, on the leg, those were bit blocked, but not sure if it is water intake. I might hit bottom (mud and gravel) with engine, maybe its just blocked?
  2. #2
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    43,551
    Default Re: Mariner 2hp overheating issue
    Quote Originally Posted by slawosz View Post
    Hi,
    Unless it has been run dry a replacement impeller will probably be all that the water pump requires but impossible to know for sure until the pump is opened up..
    It sounds as though the cooling system may be bunged up with mud etc. You may be able to flush it lelar with a hose attached ot the water tube once you have removed the gearcase unit. Otherwise you may have to separate the power head from the leg and remove the cylinder head to get it properly clear.
    The 3 holes shown in your second link are the water intake
    Take great care when unbolting any of this engine or you will break the bolts . Many outboard mechanics will not touch such old engines for this reason.
    You will find a workshop manual on the boatinfo website http://www.boatinfo.no/lib/library.html#
  3. #3
    Join Date
    Sep 2018
    London
    Posts
    86
    Thanks!
    Can I remove gear unit only by unscrewing 2 bolts which are holding lower leg, or I need to unlock shaft from gearbox as in one of above links?
  4. #4
    Join Date
    Jul 2002
    Posts
    43,551
    Thanks!
    I think you will have to release the drive shaft from the gearcase but it may depend on age /serial number which you do not quote. You may be able to remove the gearcase c/w shaft but have to then release it in order to do the water pump impeller.
    There are genuine Mercury-Mariner manuals on the boatinfo site. You should find all you need to know there
  5. #5
    Join Date
    Sep 2018
    London
    Posts
    86
    Thanks. I might actually be stupid enough to let it dry run for 30 seconds or so. I had to do like 15 pulls in order to start it before.
  6. #6
    Join Date
    Sep 2018
    London
    Posts
    86
    Quote Originally Posted by VicS View Post
    I am afraid one for Mariner/Yamaha 2 hp is unfortunately missing.
  7. #7
    Join Date
    Jan 2009
    Lochaber
    Posts
    7,145
    You might have overheated it, make sure it isn't siezed and still has compression before doing anything else.
  8. #8
    Join Date
    Jul 2002
    Posts
    43,551
    Oh . Rats. Sorry.
    I thought this one would cover it ( but I now realise its a Selc manual not the OEM one ). What year is your engine ? You did not say.
    http://www.boatinfo.no/lib/mercury/m...9_2-40.html#/0.
    Is there anything in the Yamaha section on the same site that would be relevant? No I suppose if it is older than 1984.
  9. #9
    Join Date
    Sep 2018
    London
    Posts
    86
    Quote Originally Posted by gordmac View Post
    I hope its not. I manage to run it after 5-10 minutes.
    Oh . Rats. Sorry.
    Will check later. I will try to disconnect leg in the evening. Will let know how it went in another thread, I posted there already.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
