Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    Default Horn not making a horn noise
    Itís making a noise so thereís obviously power getting through but it doesnít sound like a horn! More of a dull vibration noise.
    Any idea whatís gone wrong??
  2. #2
    Join Date
    May 2005
    up on the moors.
    Posts
    33,322
    Default Re: Horn not making a horn noise
    Is it electro-mechanical (diaphragm) horn, or a compressed air one ?
    I think, therefore I am. I am, therefore I sail.
  3. #3
    Join Date
    Mar 2011
    Rossendale
    Posts
    1,261
    When my battery is a bit low it does that
  4. #4
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    Quote Originally Posted by sarabande View Post
    Donít know. No idea how to check that?
  5. #5
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    Quote Originally Posted by Mike k View Post
    Interestingly the boat has been out of the water for a few weeks so I wonder if your theory is right.
  6. #6
    Join Date
    May 2001
    Posts
    15,467
    Almost certainly a poor connection at the switch/button. Take it apart and give all connections a good clean. Happens on my boat every now and again.
  7. #7
    Join Date
    Jun 2010
    Posts
    960
    Dull vibrations suggest electro-mechanical and the usual suspects are poor or corroded electrical connections or the horn is shot.
    If possible take a battery and wire it directly to your horn, or if it is easily removed then remove your horn and take it to your battery/batteries and run wires directly from your battery to your horn and if it works correctly you can eliminate it and check electrical connections and broken wires in electrical connections, if it doesn't work correctly then you have a defective horn.
    I am old and wise because i was young and stupid.
  8. #8
    Join Date
    Feb 2012
    Amersham, Bucks, boat in Lymington
    Posts
    344
    Assuming it's not the low battery mentioned above ÖÖ...If it's one of the single or twin trumpet Electro-mechanical set ups, the contacts inside can corrode/wear. It's a pretty simple , if fiddly, job to take the back off, clean up the contacts with fine emery cloth, give them a little bit of electrolube, reassemble with a new gasket (genuine, if you can get one, or cut out of gasket paper). and it should then work fine.
  9. #9
    Join Date
    Jun 2001
    home Brum, boat Costa Brava
    Posts
    3,943
    Does it look like this
    https://www.marinesuperstore.com/pos...0000036197.jpg
    I’ve got through half a dozen in the last decade. Now I have put a thumb screw and plug and socket and take them off (I’ve got two) when I’m not there.
    Just poor quality design.
  10. #10
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    Quote Originally Posted by DavidJ View Post
    Mine looks like an actual horn / bugle shape.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
