Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Join Date
    Jun 2013
    kent. Boat in Sant Carles
    Posts
    691
    Default Re: Horn not making a horn noise
    Had the same problem with mine last year. Ours is two different length horns side by side, linked to one vertical housing, that I guess houses the diaphragm ? Sounded like it had bad asthma..
    Was told servicing it wasn’t nigh on impossible at worst a faff at best, so forked out around £40 (from memory) for a new one.... 5 minute job to replace.
  2. #12
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    Quote Originally Posted by Andy Bav View Post
    Mine is a single horn. Sounds like a very loud vibration noise - nothing like a horn. You know what, Andy, your idea appeals to me on the basis trying to strip it down, buying a gasket, etc etc sounds like half a day of ball ache (knowing me) with no guarantees.
    New horn is £50 in our chandlers and is guaranteed to work.....
  3. #13
    Join Date
    May 2001
    Posts
    15,571
    Quote Originally Posted by philipm View Post
    Not if the switch contacts are corroded.........
  4. #14
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    In which case new horn goes back in box and taken back to chandler's!
    Jeanneau Leader 9
  5. #15
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    Okay stripped down the horn today. No obvious flaws. Horn is a very simple piece of kit. Reassembled and no change to the noise.
    Then looked underneath and discovered this horn is operated by a compressor which blows air into the horn via a plastic tube. Compressor is blowing a strong flow of air when horn button pressed at the helm i.e. compressor seems fine.
    So Iím thinking I either need a repair kit (new gasket and diaphragm) for the horn if it exists or I need to replace it altogether (but not the compressor). Problem is I canít see the brand name and a quick look on eBay / google seems to list only horns that donít use compressors or horn and compressor kits. Ideal world I would get exact same horn so the fitting through the roof is identical!
    Any ideas on whatís the easiest solution??
    Cheers
  6. #16
    Join Date
    Jun 2001
    Guernsey, Channel Islands
    Posts
    3,423
    Air horns are notably more expensive that electric. There are two makes - Kahlenberg and Marinco.
    If a good air supply is still coming form the compressor when you press the horn button, the likelyhood (apart from air leaks) is a dirty diaphragm in the horn itself. If it's a Kahlenberg, you can remove and clean it. I don't know about the Marinco.
    These are the voyages of Play d'eau....www.playdeau.com
  7. #17
    Join Date
    Feb 2012
    Amersham, Bucks, boat in Lymington
    Posts
    348
    Ok, knowing that rules out the Electro-mechanical type, so if the compressor's working ok it's got to be the horn unit itself. As Piers said, all you'll be able to do is disassemble and clean, if possible, and see how they sound but if you've done that already then it looks like new units. do the current units appear original, might be worth contacting the boat builder or owners club(?) and seeing what make/unit they are. I think you might struggle to just find replacement horns.
  8. #18
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    I've worked out that the horn is a Fiamm (Italian?) but can't find anything like it on Ebay or Amazon. It is available from EU chandlery websites - circa £100 plus hefty postage presumably - but I can't find any here in the UK. There is also a replacement diaphragm / gasket kit available from a US website for around £20 + postage but I wonder if that's worth the gamble!
    If anyone knows a Fiamm stockist I'm all ears!
    Jeanneau Leader 9
  9. #19
    Join Date
    Jan 2009
    Stratford on Avon
    Posts
    11,208
    Are your air pipes clear of water? Mine can get some water that stops the horn working properly. You might also try a bike pump to blow out the cr@p in the horn?
  10. #20
    Join Date
    May 2015
    Posts
    334
    Anything like this
    https://www.amazon.co.uk/FIAMM-92198...gateway&sr=8-3
    Make sure these are pointing down slightly so water runs out.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
