Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    Default Re: Horn not making a horn noise
    Quote Originally Posted by Croftie View Post
    Anything like this
    https://www.amazon.co.uk/FIAMM-92198...gateway&sr=8-3
    Make sure these are pointing down slightly so water runs out.
    Good shout but that's a double horn and the mounting is different. Noted re water running out!
    Jeanneau Leader 9
  2. #22
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    Quote Originally Posted by rafiki_ View Post
    Are your air pipes clear of water? Mine can get some water that stops the horn working properly. You might also try a bike pump to blow out the cr@p in the horn?
    There is nothing in the pipe between compressor and horn, also I cleaned out the horn using a cable tie (amazing amount of leaves etc in there which I thought would fix my problem) but no improvement.
    I wonder if water has got into the air compressor but there is a good force of air coming through it so I would still expect the horn to work.
    Jeanneau Leader 9
  3. #23
    Join Date
    May 2015
    Posts
    334
    Quote Originally Posted by philipm View Post
    If you only need one then you have a spare horn and spare compressor. It looks as if the horns are just bolted together.
  4. #24
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    Correct however the mounting is different so I may as well buy a completely different horn elsewhere for less ££.
    Jeanneau Leader 9
  5. #25
    Join Date
    Jun 2001
    Guernsey, Channel Islands
    Posts
    3,423
    If the boat is 12m loa or more, you'll need an approved horn to meet the col regs. Details of this (and it's orientation) are here: https://kahlenberg.co.uk/imo-requirements/
    These are the voyages of Play d'eau....www.playdeau.com
  6. #26
    Join Date
    Feb 2008
    Staffordshire
    Posts
    74
    It's a mere 9m.
    Jeanneau Leader 9
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
