Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Oct 2001
    Onboard
    Posts
    359
    Default How to remove gear from DC drive motor?
    Seeking engineering advice, I have a DC motor with a helical drive gear mounted on the shaft which is about 8mm dia.
    I want to gracefully remove it from the shaft and transplant it to a replacement motor without damage to the gear or the new motor. I can sacrifice the old motor if needed.
    I would also like to find a replacement gear wheel, just in case. I have been searching on the internet and trying to define the parameters of the gear , so far I have M1 which I think is mode 1 , Z 15 which i believe to be 15 teeth and H15 dg which I believe to be 15 degree helix. It appears to be stainless.
    Shaft diameter is 8mm
    Gear diameter 12mm
    Gear height 10mm
    Shaft height total 15mm
    Could anyone suggest a source of such gears as a one off buy and advise me whether using heat is the only way to go? i am onboard and out of the country so realistically with out an engineering shop, heat is from a butane stove on board - if this is a waste of time it would be good to know. I then need to find support or a new heat source.
    Is there such a thing as a miniature gear puller?
    Also the gear may be glued on, assuming the removal is a success, any recommendations for this?
    All advice appreciated
  2. #2
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    19,805
    Default Re: How to remove gear from DC drive motor?
    If there is no sign of a grub screw and the shaft is completely round then I suspect that the gear will be pressed on. Heating it and then hammering the end of the shaft whilst supporting the opposite end of the gear in something solid might well drive it off but you'll need a decent hammer, at least.
    Richard
  3. #3
    Join Date
    Dec 2002
    Gloucestershire
    Posts
    5,351
    HPC gears have supplied me in the past.
    I'd rather be naked
    www.mastaclimba.com
  4. #4
    Join Date
    Oct 2001
    Onboard
    Posts
    359
    No grub screw , I suspect it is heat pressed on
  5. #5
    Join Date
    Oct 2001
    Onboard
    Posts
    359
    Quote Originally Posted by Graham_Wright View Post
    Very helpful I have just called them, unfortunately not a std size so given some new ideas to follow up. Thanks Graham
  6. #6
    Join Date
    May 2003
    Fareham
    Posts
    577
    Get a bearing extractor. Loads on e-Bay
  7. #7
    Join Date
    Mar 2005
    East Sussex.
    Posts
    21,345
    Quote Originally Posted by RichardS View Post
    Richard
    If it is press or shrink fitted, which is most likely, try not to use a hammer as hammering will probably spread the end of the shaft. If there is space behind the gear you need to make a tool to pull the gear off by pressing the shaft through it. On board it is going to be difficult. Can the job wait until you get to a port with engineering facilites? Given a reasonable workshop it will be easy enough to make a puller.
    Working on immortality - One day at a time.
  8. #8
    Join Date
    Jun 2015
    Posts
    1,653
    The good news is that heat releases most glues (and Loctite).
  9. #9
    Join Date
    Nov 2017
    Posts
    47
    A decent 2 or better 3 legged bearing puller might get it off. It is most likely shrunk on - using heat to expand it before placing it on the shaft.
    The danger with a straight mechanical puller is if the gear "picks up" on the shaft - that is a small fragment of the shaft starts to roll up inside the gear pinion. If this happens you will rapidly create a locking wedge that will make simple mechanical force an impossibility.
    Using fairly rapidly applied external heat to the gear pinion to get it to expand more than the inner shaft will certainly help. But the heat will be transmitted through and so the inner shaft will then also expand at a similar rate.
    If you were salvaging the shaft then simply cutting the gear pinion off would be the cleanest solution. Since you want the pinion but not the shaft then boring/reaming out the shaft is the way to go but does then require reasonable facilities to get a clean cut of the shaft without damaging the bore of the pinion.
  10. #10
    Join Date
    Nov 2009
    Posts
    19,805
    Quote Originally Posted by madtam View Post
    That's not strictly true. The hole (the pinion in this case) will always expand slightly more than the metal filling it (the shaft in this case) if they are made of the same material, or ones with a similar coefficient of expansion. If they are made of different materials then it's more hit and miss. A temperature difference across the two will, as you say, increase the difference in the relative rates of expansion but that's often not achievable.
    Richard
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
